Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
Instructions For Fixing Hard Disk Errors - Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
    Brigadier General:
  • 10,406 Answers
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Samsung.
Press Enter
If you get a message about "disk is locked - delay disk-check until next reboot", click OK, and shutdown/reboot Windows.
When "check-disk" has finished, any correctable errors will have been corrected.
Posted on Nov 13, 2010
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
note
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Tip
PS3 Problems - FIXED AT HOME!!!!
My name is Paul Thompson and I have been running a PS3 Repair business from home for the last 2 years.
The reason I have decided to make this video guide is is because I am SICK of seeing people forking out money for repair work that does not need to be done in a factory!
I also literally do not have time to repair all of these broken PS3's from home! No kidding at one point i was fixing 15+ a day!
I have designed a video guide that ANYONE can use to fix ALL errors with the console in less than 1 hour from home!
Preview of the guide Chapters
1. Cooling it down
2. The Reset Trick
3. Clean your PS3. internally
4. Format the newly installed Hard Drive (Only if you recently installed a new Hard Drive upgrade!)
5. Fix All Flashing lights yellow/red/green/blue.
6. PS3 Red Screen Of Death Fix
7. PS3 Freezing problem
8. Power Supply Malfunction
9. Hard Drive Failure/Reinstallation
10. Fix all Error messages
11. Fix Disk Drive - Disk read errors - Disk stuck
5 Professionally made Video's for all fixes, easy step by step instructions just do what you see.
SEE MY OFFICIAL WEBSITE HERE - GET BACK TO GAMING TODAY.
MORE INFO - Full review from the PS3 problems team
on Jul 05, 2010 | Sony Playstation 3 (PS3) Console
I have a Easy Note TE11BZ laptop, it is stuck on Preparing automatic repair, diagnosing your PC, fixing disk errors. Any help solving problem.
Pull the battery, and unplug the power. After about 10 minutes, just plug in the power. Leave the battery out. If it is still diagnosing your PC and fixing disk errors, let it run. These newer, larger hard drives take a long time to fix. I've had some take up to 3 hours.
Aug 25, 2013 | Packard Bell Computers & Internet
Unmountable boot volume
If your notebook came with a Windows installation disk, you can fix the issue this way:
1. Insert the installation disk into your CD/DVD drive, and boot up your computer.
2. At the Welcome screen, hit the R key on your keyboard. This will launch Recovery mode.
You should now see a DOS prompt on your screen.
3. Type chkdsk /p and hit Enter. This will launch a utility that scans for hard drive errors.
The process may take some time, so be patient and allow it to do its job.
4. After the chkdsk is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When prompted to choose "Yes" or "No," type Y for "Yes."
5. Type exit and press the Enter key to reboot your computer.
Assuming chkdsk was successful in fixing the disk errors, you should now be able to boot back into Windows.
If you do not have a Windows installation disk, but have access to another computer with a CD/DVD writer, you can download Hiren's Boot CD to help fix your corrupted boot drive.
1) Download the Hiren's disk image, and follow these instructions for burning the boot CD.
2) To ensure your system boots from the CD you've created, follow these instructions on how to set your BIOS to boot from CDROM.
3) Alternately, you can download a free utility that will create a bootable USB flash drive containing all of Hiren's tools. The above link also provides step by step instruction on creating a Hiren's USB drive, as well as how to set your BIOS to boot from it.
4) Boot the problematic pc from either your Hiren's CD or Hiren's USB drive.
5) Once you've successfully booted your system using Hirens, you will see a menu with a variety
of tools and utilities. Navigate to the hard disk tools menu, and run HDD Regenerator.
You'll need even more patience this time -- as HDD Regenerator is a bit more comprehensive in its error scanning than chkdsk. On the bright side, HDD Regenerator has a reputation for repairing disk errors that chkdsk was unable to.
Good luck, and I hope this helps!
Jan 08, 2011 | Dell Inspiron 6400 Notebook
Boot disk failure no hard disk found
The error means that your system is not able to detect the hard drive on the system, check if the hard drive wire connections are tight and not loose and then try rebooting the system.
Look for hard drive stats on POST whether it succeeds or fails. This is how you can do that.
When system boots up, press the PAUSE?BREAK on the black screen and see whats system comment for your hard drive power test. If it succeeds and your hard drive's connections are also tight then possibly your hard drive might have crashed ( which means there are bad sectors on the hard disk).
Try performing disk checking on the hard drive to see if there are any bad sectors on the hard disk, the disk check will automatically fix the soft errors but if the errors and hard errors in that case the disk checking utility will not automatically fix the errors and you will need to get a new hard drive.
Thanks !!!
Nov 22, 2010 | Computers & Internet
My laptop gave me no problems except for occasionally going into hibernating and not being able to wake it so i would have to manually shut it down and turn it back on. but last week i dropped it and...
The BIOS update could have caused the unit's fan regulation to fault.
the check disk and actually fixing errors woudl point to the Hard Drive being damaged and needs to be replaced. A full diagnostics is what needs to be done to determine this, i would tell you how but multiple hard disk brands are used on these systems.
The BIOS update may have also changed the performance settings on the unit, this will cause the system to use the CPU maxxed all the time. This will kill the battery quicker. You can check this setting in yoru BIOS.
Jun 03, 2010 | Acer Aspire 4720 Notebook
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
Instructions For Fixing Hard Disk Errors:
Reply to :- Instructions For Fixing Hard Disk ErrorsThe same problem is my window 7 is showing on my hard disk Disk Name: WDC WD2500BEVT-75ZCT2 ATA...
I can still access to my data but my laptop hangs a lot..
my laptop is Dell Inspiron 1525.
Is my hard Disk got failed?
I am very much worried...please someone help me.
Aug 11, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Maxtor 160gb External Hard disk stoped working
You're probablly SOL but-
You can help solve some computer problems and improve the performance of your computer by making sure that your hard disk has no errors.
  1. Click on start, then computer (or my computer)
  2. Right-click the hard disk drive that you want to check, and then click Properties.
  3. Click the Tools tab, and then, under Error-checking, click Check Now. getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    To automatically repair problems with files and folders that the scan detects, select Automatically fix file system errors. Otherwise, the disk check will simply report problems but not fix them.
    To perform a thorough disk check, select Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the hard disk itself, and it can take much longer to complete.
    To check for both file errors and physical errors, select both Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
  4. Click Start.
Depending upon the size of your hard disk, this may take several minutes. For best results, don't use your computer for any other tasks while it's checking for errors.
Note
  • If you select Automatically fix file system errors for a disk that is in use (for example, the partition that contains Windows), you'll be prompted to reschedule the disk check for the next time you restart your computer.
Mar 11, 2009 | Maxtor Hard Drive
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
282 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
