Question about HP PSC 1610 All-In-One Printer, Scanner and Copier
I have tried cleaning it...back rollers don't turn
  • 10,515 Answers
This usually happens when the roller is covert with a lot of dust/dirt or lint or it is completely worn out. Clean the rollers and see,if that helps the problem to be get resolved. Unless, you need to replace the rollers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 13, 2010
Dryer tries to turn but then shuts off
Hi espichfamily
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley this will cause the drum not to roll.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Oct 11, 2012 | Amana NED7200TW Electric Dryer
My rollers don't turn
may sound stupit but are the rollers clean and does the pice in the middle that turns them turn when its not in or is the wrong playe in there or your belt could be broken that turns it
Sep 28, 2012 | Microwave Ovens
Paper wont feed 11x17-keeps jamming ( problem with the rollers?)
For first clear rollers w/alcool or orig clearing solvent. If it doesn't solve Your problem remove the rear cover and controll the little fingers hanging in the way of sheet edge. Some of them may be in wrong position because of missing or released spiral. Fix it back with a medical clip or you may remove the whole finger (one piece) if You don't find the spiral. Control and clean the turning surface.
You need strong light in the spot because of the usally black accessories.
Don't miss monthly cleaning procedure.
May 15, 2012 | Canon ImageRUNNER 3235i Black and White...
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
Once I turn my printer psc 2410 photosmart on it makes an annoying sound like if something is stucked and freezes staying on the clock sand mode . What should i do?
During printing, the HP product makes unusual or loud noises. You might describe the noise as grinding, squeaking, or screeching.
    Step one: Clean the rollers in the back of the product
    1. Disconnect the power cord from the back of the product.
    2. On the back of the product, find the rear door.
    3. Squeeze the tab or tabs on the rear door, and then pull the rear door toward you to remove it.
    4. Open the rear door on newer Photosmart, Officejet, or PSC productsInside the back of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
    5. Rotate the rollers located on the inside of the rear door to make sure that they can turn freely.
    6. Remove any torn pieces or scraps of paper that you can see.
    7. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the paper rollers inside the product and on the inside of the rear door clean. Rotate the paper rollers with your fingers to clean all the way around them.
    8. Reattach the rear door. Make sure that it snaps into place.
    Step two: Clean the rollers in the front of the product
    1. Lift the cartridge access door to access the front paper rollers in the product.
      NOTE: On some Officejet models, you might need to close the document catcher. Then, look in through the front of the product to access the front paper rollers.
    2. Inside the front of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
    3. Remove any torn pieces or scraps of paper that you can see.
    4. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the paper rollers clean. Rotate the paper rollers with your fingers to clean all the way around them.
    Step three: Clean the small rollers Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the small rollers, also called the pinch rollers, clean. The pinch rollers are the small metal rollers directly above the paper rollers. Rotate the pinch rollers with your fingers to clean all the way around them.
    NOTE: Do not clean the carriage rod. Removing or damaging the lubrication on the carriage rod can cause the product to make more noise. Figure 9: Carriage rodc02203348.jpg Step four: Clean the cartridges
    1. Connect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
    2. Open the cartridge access door. Figure 11: Lift the cartridge access door on newer Officejet, Photosmart, and PSC productsc01940403.gif
    3. When the carriage stops moving, disconnect the power cord from the back of the product.
    4. Press down on each cartridge to release it from the carriage, and then pull it toward you out of its slot.
      NOTE: You might need to lift a cartridge latch before you can remove the cartridge from the product. Press down on each cartridge to release it
    5. 1 - Tri-color cartridge 2 - Black cartridge
    6. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe any ink or debris from the copper-colored electrical contacts on the cartridge.
      CAUTION: Do not touch the ink nozzles or the electrical contacts with your fingers. This can result in clogs, ink failure, and bad electrical connections. Figure 13: Clean the copper-colored electrical contactsc00617184.gif 1 - Electrical contacts 2 - Ink nozzles Figure 14: Do not touch the copper-colored electrical contacts or the ink nozzles Place the cartridges on a clean sheet of paper, with the nozzles facing up.
    Step five: Clean the electrical contacts inside the product
    1. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe any ink or debris from the electrical contacts inside the carriage
    2. Let the cartridges and carriage sit for 10 minutes to allow them to dry, or use a clean, dry swab to dry the contacts.
    3. Slide each cartridge into its slot at a slight upward angle, and then press firmly until you hear the cartridge click into place.
      • Install the tri-color cartridge in the slot on the left.
      • Install the black cartridge in the slot on the right.
      I hope this helps you!
May 26, 2011 | HP PSC 2410 All-In-One InkJet Printer
Forgive a naive question from a technical dud. My Laser MFD 6020 has worked well - until it began paper jamming today. I can't easily pull the paper out frontwise without seeming to do violence to...
clean any paper dust from the paper path, something is blocking somewhere,
theres too many factors to give an exact diagnosis...but !!!
if the paper is
completely blank where jamming it maybe time to order a new set of pickup rollers, which just collect the paper from the bottom drawer, should just pull off and easily replaced and are cheap, you can clean these with soapy water as long as you thoroughly dry them before putting back.
if the toner is on the paper but its not dry...smudgy, try the transfer drum, either check theres no small tears of paper or excess dust in that area,(DON'T CLEAN WITH CLOTH relies on static charge) a few light blows of air should be enough..replace if need be but they're expensive.
if the papers printed and dry where jamming its going to be in the area of the fuser (the hot roller) this can be cleaned with dry clot, don't use any solvents ore cleaning products...ALLOW TO COOL first or burn your fingers.
if the papers crumpling anywhere along the line there is a roller not turning maybe due to a stuck piece of paper from a previous print, the roller not turning is obviously between the front of the paper and the crumple.
Apr 20, 2011 | Office Equipment & Supplies
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Hp 1210 paper will not feed
Hi ihimc1, over time dust and paper fibres can cause the rollers to stick, which can result in the paper not feeding please take these steps below to clean the rollers.
Turn off the all-in-one.Unplug the power cord from the back.Remove the rear access door. Clean the rollers one at a time using a clean cloth that is slightly dampened with water. Rotate the roller to clean the entire surface. Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
Reinstall the rear access door and then plug the power cord back in.Turn the all-in-one back on.
Nov 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
21 people viewed this question
Seeker5211
Seeker5211
