Question about HP PSC 1210 All-In-One InkJet Printer
WHEN TRYING TO PRINT THE MESSAGE COMES UP THAT THE INK CARTRIDGE IS INCORRECT... AND WILL NOT PRINT. SAME CARTRIDGE FOR THE PAST 5 YEARS.. ?? MAC COMPUTER.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Either catridge is deffect, or contacts are dirty; using a lint free damped cloth clean contacts on both cartridge and cartridge holder.
pls. vote for better service... thanks.
Posted on Nov 13, 2010
The printer won't print. Instead, an error message appears that says, "The type of print head is incorrect. Install the correct print head." Why this now, since I've been using the same printer...
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or isopropyl alcohol to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work, then you need to try soaking the print head. In this case:
(1) Remove the print head from the printer
(2) Soak it in hot water for an hour or so
(3) Remove it, let it dry completely
(4) Replace the print head and cartridges and test it
Feb 24, 2014 | Canon Pixma MP500 All-In-One InkJet...
Have error message UO52 print head is incorrect, have installed correct ink cartridges what do I do ?
It could in fact be a defective print head problem but try cleaning it first:
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
Jul 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
We keep getting left cartridge incorrect message?
Are you using Dell Series 5 ink cartridges?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jun 12, 2011 | Dell 946 All-In-One InkJet Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
My Kodak ESP 5 Won't print entire documents, only first page
Scott,  If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
Feb 03, 2009 | Kodak ESP 5 Printer
Lexmark 4530 right cartridge incorrect message. unplugged unit, cleaned cartridge nothing works.
The compatible cartridges for the X4530 Lexmark printer are the # 23,23A,24,24A,31,34,35. If you have the correct cartridge number and still says cartridge incorrect, try this steps.
1. Get a damp and a dry paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. ( try this for around 5 times )
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. ( try this around 5 times )
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Remove the power adaprtor behind the printer.
6. Using the dry paper towel, clean the metal contacts on the cartridge carrier inside the printer. ( try this 5 times )
7. Place the Cartridge back to the printer, connect the power adaptor.
8. Check if there is any error message. If same problem persist, try to contact Lexmark Technical Support.
Dec 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Print head
That is a strange message unless you have changed the print head recently (or it has become defective). The first thing I would do is try reseating the print head.
Unplug the printer.
1) Remove the 5 ink cartridges.
2) Lift the lever that is just to the left of where the ink cartridges sit. This is the print head lock level.
3) The print head is located under the ink cartridges (if they were still there) lift it out carefully.
4) Inspect for damage but do not touch anything or it can cause problems.
5) Carefully replace print head and lower level until it clicks
6) Replace ink cartridges
Plug in the printer and test.
If you still have a problem -
Call 1 (800) 828-4040 for warranty part replacement or to order a part out of warranty.
Oct 06, 2008 | Canon MP830 All-In-One Printer
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
Sep 03, 2008 | HP Officejet 4355 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
15 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
