Question about Rowenta DX-8800 Iron
DX8800 iron power light (red in handle ) comes on but, no heat to foot and water comes out the bottom hole on each side of foot when tipped one side or the other
    Genius:
  • 1,672 Answers
Ur iron needs to check and adjust the THERMOSTAT SWiTCH for the heat! Check also the THERMAL FUSE that might been blown and replace it w/ similar part! U need to bring that iron to ur electronic technician if u can't dismantle it to adjust and replace the said parts! hope that may help u out!
Posted on Nov 13, 2010
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
My Rowenta Professional Iron just stopped heating. What do I need to do. Could it be that the iron needs cleaning and how would I do that?
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 11, 2010 | Rowenta Professional DX8800 Iron
Iron will not heat up
heatman101
Jun 06, 2010 | Tefal UltraGlide Easycord FV4256 Iron
IT LEAKS WATER OUT OF THE BACK AND BOTTOM
There might be a crack or the water sealed container isnt sealed correctly so you can either take apart your iron and calk it with water proof sealant or you can buy a new one before you get electricuted
Jan 02, 2010 | Rowenta Professional DX8800 Iron
Water leaks
poly seal{white} perished where comes from tank to element plate
Nov 17, 2009 | Irons
How do I clean a rowenta DX8800 iron that leaves deposits on my garments
Use a white vinegar and distilled water solution in the iron, but don't do any clothes with it. Let it soak for a while, then heat the iron and let it blow out any debris. Fill again with distilled water, shake well, and let it steam out. Do this again until there is no vinegar smell coming out. If you use only distilled water, you should have no further problems like this.
Sep 18, 2009 | Rowenta Professional DX8800 Iron
Leaking professional luxe iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jul 19, 2008 | Rowenta Professional DX8800 Iron
Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
Feb 12, 2008 | Euro-Pro Shark GI490 Iron
Rowenta DX-8800 Iron Logo
255 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
