Question about ACCO Brands Kensington Ci10 Fit Wireless Notebook Laser Mouse
This new K72335EU mouse will not move the cursor on the screen. The scroll wheel works and so do the right and left click buttons but nothing happens when I move the mouse on the mat or wooden table. I have tried different batteries and moving the USB receiver to a different port. No change. The UK tech.support 020 7949 0119 does not appear to be open today-Saturday. I have a Dell Inspiron 9400 laptop with Windows Vista. The packaging was just thin cardboard.
4 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: Kensington Ci25m use with Widows Vista
yes it will. I checked out the specifications on the website. Just google Kensington Ci25m with Vista and you'll see it..
Posted on Feb 28, 2009
  • 42 Answers
SOURCE: mouse stopped working
Check underneath for dirt or debris blocking the laser light lens, try on a different surface ie (mousepad). If that doesn't solve your problem, it's time for a new one.
Posted on Jun 19, 2009
  • 811 Answers
SOURCE: I have a Kensington Ci65m
Mice are pretty cheap just replace this mouse and get another one. You can spend time taking it apart and trying to fix it or make some other USB connector work with another mouse so on and so forth. Just go and purchase another mouse that would be really much easier. I hate to say it. I guess that is my humble opinion odds are that you will be doing that anyway. Thanks for using FixYa! John
Posted on Apr 13, 2011
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
How to ouse the mouse?
The mouse is used by people to navigate around the operating system like Windows.
There are a number of buttons on the mouse, Left Click, Right Click, Scroll Wheel and Wheel Click.
Your index finger operates the Left Click and you middle finger operates the Right Click and Scroll Wheel.
The mouse, when moved in turn moves whats known as a cursor on the screen, it's that arrow.
Think of the cursor as your pointing finger.
Hope that helps!
damnor01
Jan 08, 2011 | Computers & Internet
My pc desktop is moving left & right with cursor of mouse
It sounds like you have zoomed in on your screen image, so your screen is showing you only a portion of your desktop. In this situation, you move to a different region of the screen using the mouse cursor, as you describe.
You can zoom back out by holding down the CONTROL key while rolling your mouse's scroll wheel (or scrolling with two fingers on the surface of an Apple Magic Mouse).
May 12, 2010 | Apple iMac 17" Desktop
Mouse has a mind of it's own...often skipping across the screen without any assistance. Is there a patch available?
it might be due to scroll speed of mouse going bit high.
to adjust the same...click on start...control panel...mouse icon...mouse properties window would open... click on the pointers tab...adjust the pointer speed setting... this should help in fixing the issue.
regards
Jan 31, 2010 | HP P2360AA Keyboard/Mouse
Cursor moves but when i tap it nothing happens?
Down on your task bar on the right there is a little screen that shows a green circle when you move your cursor. This is the Synaptics Pointing Device. Place your cursor over that and click your left 'mouse' button (just below where you tap). You will see 'tap to click'. If you click on that it will change it to your 'tap' function. That should solve your problem, hopefully. Hope this helps.
Oct 14, 2009 | Toshiba Satellite Pro L300 Notebook
USB mouse is jittery
Try the mouse on a different surface, also be sure you do not have any light directed at the mouse - this confuses the eye. Although no mouse pad is required for an optical mouse, sometimes it helps
Apr 01, 2009 | HP USB Optical Scroll Mouse
Microsoft wireless laser mouse 5000
Assign a keystroke to the mouse, in this instance I assigned 'p' for pan (as per the .pgp file short cuts etc) against the scroll wheel click.
Click the scroll wheel, 'p' comes up on the cad screen, right click to confirm then the pan icon appears, hold the left mouse button and drag at your leisure. Yet to find a fix for Inventor.
Not ideal, but better than nothing at presnt.
Jun 08, 2008 | Microsoft Wireless Laser Mouse 5000
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
ACCO Brands Kensington Ci10 Fit Wireless Notebook Laser Mouse   Logo
Top ACCO Brands Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
handyguy54
Level 1 Expert
Are you an ACCO Brands Computer and Internet Expert? Answer questions, earn points and help others
