Question about Lands Phones
Samsung iDCS100 - no lights on MCP. Power supply OK. Handsets only displaying Software version (2.2) and year built (2003 4.3)
  • enquiries913 Nov 14, 2010
    I have been told by a friend of mine who works for a telecom company. It is something to do with the power supply unit. We managed to find a second hand unit to change it and the problem is now solved. Many thanks for the help.
  • Lands Phones Master
  • 4,737 Answers
I don't think this is a Display problem since there's something more i.e "displaying Software version (2.2) and year built (2003 4.3)". I am sure that this is a new issue as there are no similar complaints yet. I suspect the internal memory (Flash memory) or a processing unit issue. Well do you hear any beeps or something on the earpiece when turning it On/Off?.
I've posted the issue to the Samsung Support Team with the details, but I still need more info from your end so that I can do some more research and experiments.
While awaiting for the response from the Samsung Support Team, it'll be great if you could let me know details about the problem, how this happened etc... Thanks.
Posted on Nov 14, 2010
  • Lebanon Raingam
    Lebanon Raingam Nov 14, 2010
    Oh... that's great...
    Thanks for using FixYa.
Samsung LED40"UA40EH5000R no picture sound ok
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
May 16, 2015 | Samsung Televison & Video
UndefinedHi I have a Dk smith HD LCD TV model GE-6824,approx 2 years old,display doesnt work now,just black,will turn on ok turn off,green light-red light,but no picture,any idea.And yes its just out of...
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 13, 2015 | Televison & Video
How to clear codes
i found this in another place
Quick Test Mode
Note: This test erases all faults and memory:
To enter press Spin, Soil, & Power
simultaneously with the power off.
1. All LED's light up and the washer beeps as it
enters the Quick Test Mode.
2. The unit displays the software version for a
second then clears the EEprom.
3. After the displaying the software version, LCD
will display Model information.
If EEEE is displayed the PCB assembly is defective.
For production up to 03/31/2009 Serial **S3**
4. When the version is displayed. Press the following
keys to test the various components.
Effective 4/1/2009 Serial **S4 ** a change was
made.
4. After the displaying the software version, turn
the Jog dial CCW to display "F4". Press the following
Press Temp Key to cycle through the Water Valves in
this order: Cold Main, Bleach, Cold Main & Bleach for
Fabric Softener, Hot, then off.
Press Spin Key to test Motor circuit.
Press Signal Key to test Drain Pump
Press Soil to test door lock - unlock circuit
Mar 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
My ViewSonic VX900 won't turn on. I have had it since late 2003 and it has operated flawlessly. Went to turn it on; nothing. No light, no standby light. Checked the power cord against another monitor and...
The VX900 has 2 different version of the unit. One version has an external power supply and the other has internal power supply. Since you said you changed the power cord I would guess you have the internal power supply version. The issue you have is caused by the capacitors on the power supply board have overheated and blown out. This is a common problem on many LCD monitors after a few years of use. If you open the back of your monitor and look at the supply board you should see the bulging capacitors. Check our web page at: www.ccl-la.com for Pictures and examples of what to look for and what you need to get to do the repair. If you have any questions let us know on our web site and we will be glad to help you get going again.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | ViewSonic VX900 19" LCD Monitor
Samsung 225bw display with NO VIDEO and flashing power button
A flashing power light and no picture is a sure indication of a shorted power supply board. There are parts called capacitors that fail and this causes the power supply to continuously shut down and restart over and over, hence the power light flashing. If you can do a little soldering then you can repair the unit. Here is a link to a service guide showing how to dis-assemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
I hope this helps, if so please ratre my solution.
BuddyMc
Nov 22, 2008 | Samsung 225BW Monitor
Ga-7N400E powerup problem
VRM Circuit problem found there
disconnect only core voltage connetor and power on motherboard
if motherboard on so confirm that your vrm circuit is sort
replace vrm circuit mosfet
Feb 23, 2008 | Gigabyte GA-7N400E-L Motherboard
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
