Question about SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400
MY COMPUTER DIED. HOW DO I TRANSFER THE FILES FROM MY VERBATIM SMARTDISC FIRELITE 160 GB, USBFLB160' TO ANOTHER COMPUTER? THANKS...........................JOHN NICKERSON
    Brigadier General:
  • 10,406 Answers
It depends on how you copied your files to the SmartDisk.
If you used the "normal" method of copying files/folders in Windows, then just connect it to the new computer.
If you used some "backup" software from Verbatim to write "backup" files,
then you'll need to install that software on the new computer,
in order to retrieve from those "backup" images.
Posted on Nov 13, 2010
How do I delete files from flash drive--wipe clean
Cleaning a Flash Drive
Put the flash drive into your computer's USB port (assuming you have the proper driver loaded onto the computer). Go to "My Computer" and highlight the drive that shows up, right-click and select "Format." That'll wipe it completely clean.
Or, if you just want to remove the files, do the same thing but instead of formatting, just highlight the files and right-click to delete the file, pix, or whatever.
Jan 02, 2011 | Verbatim 160GB USB FireLite: The "drive...
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
I just installed verbatim 250 gb hard portable hard drive How do I get the files I want backed up to save to the drive. No Instructions
there should be a disk that has backup software on it that came with the HD.
if you just want to do simple back up just open up Mycomputer or windows explorer addn drag files to the new hd, like the my documents folder.
Oct 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
External hard drive does not display icon in My Computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim firelite external hard drive
ok...well...then if it is compatible with your current operating system, then it should work. is this a first time install?
Oct 13, 2008 | Verbatim SmartDisk Firelite Portable USB...
How to back up photos on MacBook
From within iPhoto, try saving/exporting directly to the drive.
Jul 09, 2008 | Verbatim SmartDisk Firelite Portable USB...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Open Questions:
SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400 Logo
200 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
