Question about Kenmore Vacuums
Sears Kenmore Upright Vacuum Model 116.36822500 Diagram of how to install belt 20-5275
VacuumRepair
  • 438 Answers
SOURCE: Belt broken a a Kenmore
Greetings from GoVacuum.com,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 01, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
SOURCE: my kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
Posted on Dec 05, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same issue. The holder for the micro switch is very weak and will open up and allow the switch to come loose, and in my case the was not enough slack in the wire. I unplugged the unit, pressed the pedal and laid it down. Open up the bagger door and remove the bag and filter. Remove 4 screws in the bagger compartment, remove 2 screws by InteliClean indicator lights, remove 4 screws on the outside close to the light. You will be removing the blue upper case. Remove the upper case and look on the right where the lower agitator section pivots. There you will see a micro switch. I ended up lifting and tilting the lower pivot section to the side, repositioning the switch in the holder, and then wedging a full glue stick (not melting but wedging) between the white plastic housing and the switch holder. This added the strength needed to the switch housing to hold it in place. Put it all back together, install the filter and bag. This fixed mine. Good Luck.
Posted on Feb 27, 2010
How do I change the belt on the 116 model?
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
Brush will not turn
The vacuum needs a new belt. Check the brush roller, if it turns easily without resitance, it needs a new belt. Get your model number off the back of the machine. It's on a sticker near the floor with UL logo on it. Go to Sears and gets some belts.
Apr 16, 2010 | Kenmore Progressive Bagless Upright with...
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
I need a belt for a kenmore 721 vacuum please
Should be able to get one at local Sears store , or try sears.com
Feb 13, 2010 | Kenmore Vacuums
Oct 26, 2008 | Kenmore 34612 Bagged Upright Vacuum
Belt broken a a Kenmore model 116 canister vacuum
Chris Jones
GoVacuum.com
Sep 29, 2008 | Vacuums
Non spinning brush
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632342
Generic problem for all Vacuums
Non spinning brush
Posted by tillie14 on May 29, 2008
I have a Kenmore upright beltless that suddenly, the brush stopped spinning. Do you have an answer for this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Kenmore upright the belt is broken and needs replacing and you can take it to Sears / Kenmore or a local vac dealer and they can change it for you or you can attempt to do it yourself, usually it just takes a screwdriver and either a flat or a geared belt for less than $10.00 to $15.00 is an estimate.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Clogged vacuum/Need Manual
You will have to go Sears.com, click on the the parts link, enter you model number, a parts list will come up. but there is a view diagram link to show you a picture of the parts breakdown.
Jan 05, 2008 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
375 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
