Question about Canon PIXMA MP210 Photo All-In-One Printer
I can not install my canon pixma 258 to my computer because it always says print spooler is not running \
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Check out this link
pls. vote for better service... thanks
Posted on Nov 13, 2010
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 25, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
My canon pixma mp 258 inkjet not scan. error message display on printer is in use or an error has occured.scanner driver will be closed. how can i solve
Hello! Please go to Control Panel and un-install your Canon Pixma Mp 258 Driver... now restart your computer and re-install the same driver (i.e. your printer driver) to solve your problem.
Note : Do not forget to select Easy Install.... thanks
Sep 23, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Hello, I have problem like this - Process cannot continue because the Print Spooler service has been stopped. Restart the computer to start the Print Spooler & try again. I mean, I cant even install it...
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 28, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
My print spooler is not running
If you are getting a message that your print spooler service is not running, possibly you have the print spooler service turned off.
To start the print spooler service in XP:
Click on Start
Click on Run
Type "services.msc" and hit Enter or press OK
In the services window look for "print spooler service"
Click on the Print spooler and on the top left corner Click on "Start"
Reboot the computer. You should be able to print now.
Please get back for any further assistance.
If you find this resolution helpful, please do not find to leave your comments and ratings.
Thank you for choosing Fixya.
Feb 26, 2010 | Canon PIXMA iP1600 Printer
Canon Printer Installation
The print spooler is located in services. Start, run,(type) services.msc, then ok. Double click print spooler and start the service. Also look under the dependency tab and make sure all dependent services are running.
Sep 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error message -----print spooler not running reboot system. I have tried that several times with no success
It's not a printer problem, but you may need to delete and re-install your printer driver on your computer to resolve the spooler problem.
Aug 27, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Operation failed due to print spooler.
Try downloading the drivers from the following location. This should solve the issue:
http://software.canon-europe.com/products/0010383.asp
Apr 09, 2009 | Canon PIXMA iP1300 Printer
Cant install printer
If you are on Vista, type 'Services' into the search bar, or if you have XP, Run 'services.msc' and press enter, and scroll down to Print Spooler. Right-click on it and choose Restart.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Canon PIXMA MX300 All-in-One Printer
My Canon PIXMA MP240 all-in-one will not install the drivers or any of the associated software. I follow the instruction manual perfectly and get the following message when ever I try to load the...
I had the same issue!! I called up Canon Australia on 13 13 83.
The gentleman explained that even thought it was called Print Spooler, it was my laptop.
Start Menu > Run > services.msc
Long list of items > scroll down to Print Spooler
STARTUP TYPE SHOULD BE "AUTOMATIC"
AND SERVICE STATUS SHOULD BE "STARTED"
if it's not, click "Start" > then Apply
no need to reboot - try installing the drivers now.
Good luck! If this doesn't work, call Canon tech support in your country :)
Cheers!
Kayo
Oct 26, 2008 | Canon Office Equipment & Supplies
Printer Spooler Service turns off when I try to print
Un-install the printer and it's associated software via the Control Panel of your Windows PC.
Reboot your computer with the printer turned off and the USB cable unplugged.
Go to the Canoin web site and download the latest version of the driver for your operating system.
Run the driver install following the instructions in the install wizard.
Once the wizard is done, you should be OK again. If not, reboot and test the printer again. If it is still not working properly then you probably have a Windows problem and not a printer problem
Sep 15, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
120 people viewed this question
old marine
old marine
