Question about Lanier 1205 Copier
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
  • Lanier Expert
  • 398 Answers
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Posted on Nov 16, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
236 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
