Question about Garden
Oil not coming onto the chain out of the saw make of chain saw is a Stilih
  • 520 Answers
I have had the same problem with mine. i dont know what model you have so i may offer some advice that dont apply to you. on the bottom of the saw is the oil adjust screw, hard to find. turn it up and see if that makes a difference. the oil passage is probably plugged with saw dust. take the air hose to the saw and give it a good cleaning. if that still does not oil the it may have to go to the shop for a better cleaning.
Posted on Nov 13, 2010
How to adjust oil to chain on poulan 18" 42cc chain saw
Poulan chainsaws are at the cheap end of the spectrum when it comes to good chain saws. I had the same chainsaw and there is no oil adjustment. Basically, the Poulan oil feeders just drool onto the chain....whether it is running or not.
Nov 15, 2017 | Poulan Garden
CSP4518 model. There is way too much oil coming onto the saw and bar in use and I can't find anything in the users manual. Any tips?
check that the jet where the oil comes onto the bar/chain has not being plucked out during operation
use chain bar oil , not engine oil
Apr 12, 2015 | Homelite Garden
(This may be a duplicate- not sure if my first attempt was submitted). Chain oil delivery failure. No oil comes onto chain when engine running or onto ground if chain & guide removed. Can see...
This is very strange if the saw is new, it cant be dirt in the tank or filter, i think it is more likly a kinked oil hose in the oil tank, i dont mean to be sarcastic but you have put the chain oil in the oil tank? is this a Husqvarna machine? if so let me know the model, so as i can be a little more helpfull.
Feb 09, 2011 | Garden
I have a husqvarna 257 with a 20inch bar and having oiling problems, is getting hardly any to no oil and have the oil adjuster screw the whole ways out, is the oil plunger bad?
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Sep 14, 2010 | Husqvarna Chain Saw 20" Bar
My remington 16 inch electric chain saw is not oiling, how do i fix it?
Start by making sure it's unplugged. Then remove chain, and bar, and clean oil slot in the bar and all of the housing in the area the oil comes out onto the bar. I use carb cleaner (safer than gas) and then empty and clean the oil reserve. Refill with straight 30 weight. Never use car oil like a 10w30 or 5W40! Then prime (pump) and start the saw without chain or bar. You should see some oil squirt out. If not, soak a clean empty oil reserve overnight in carb cleaner and try again.Once the oil path is clean, you should be back in business. If not - see your authorized service center.....LOL
Jun 17, 2010 | Remington 16" Electric Chain Saw Assembled...
Where can I find a replacement bar and chain for my saw?
Remove the bar and chain from the saw. Take these parts to a saw servicing dealer who can match the bar and chain. Be sure to clean the area where the bar mounts. Run the saw for a few moments--the oil port in the side of the case should ooze out oil. Install the bar first, then thread the chain onto the sprocket, then work it over the bar. Pull the bar out until the chain is fairly tight, then fit the cover, but leave the mounting nut(s) finger tight. Turn the chain adjuster until the chain doesn't droop from the bar, but still be able to turn the chain by hand. Tight the mounting nut(s) and recheck tension. Run the saw at full speed with the tip near some cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Jun 10, 2010 | Desa International 100089 06 Electric...
Husqvarna 350 oil not getting to chain
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
May 26, 2010 | Husqvarna Chain Saw 20" Bar
Where do i purchase chain saw oil for electric chain saw
Hi
It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership.
Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine.
The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up.
The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also:
http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed.
HF
Feb 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Excessive chain oil coming from oil tank onto the chain.
there is a screw right next where the oil comes from need to turn it clockwise ,unless it came off
Dec 27, 2008 | Husqvarna Chain Saw 20" Bar
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
