Question about PfaFF Creative 7570
Threading a pfaff 9020 sewing machine - PfaFF Creative 7570
  • PrettyPocket Jul 31, 2008
    I have a problem threading my Pfaff 1536. It's almost like it threads backwards (left to right instead of right to left). I REALLY need a diagram because it just is not sewing correctly for me.
  • Anonymous Mar 27, 2014
    Need a diagram
  • 323 Answers
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Jun 19, 2008
How do I fix the tension on a 140s smarter by PFAFF sewing machine?
Depends what exactly is happening with the tension.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
HINT: ALWAYS RAISE the presser foot when threading the top thread!
Jun 25, 2017 | PfaFF Sewing Machines
How to thread pfaff 9020
Try this site:
https://www.hunker.com/12460714/how-to-thread-a-pfaff-sewing-machine
May 08, 2017 | PfaFF Sewing Machines
How to thread a pfaff 2042 machine
You might try contacting Pfaff Support:
Machine Support
May not be your model, but frequently machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading.
Threading Pfaff Sewing Machine Select mov
Manual:
Pfaff quilt style 2042 manual
FAQ Knowledge Base
Dec 17, 2016 | PfaFF Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Jan 18, 2010 | Sewing Machines
Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
May 20, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
429 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
