Kenwood A97 Amplifier will turn on then go straight into "PROTECT". I lose all control of the amp, I'me tried disconnecting and reconnecting the speakers, made sure its all wired up properly and even checked the fuse in the plug but still nothing
  • rando30 May 15, 2009
    same problem
Hi can you please tell me what is the solution
Posted on Mar 31, 2009
Help! im having the exact same problems with this model
Posted on Aug 28, 2008
I have a kenwood stacking system. But no manual with it I am trying to connect turntable p97 to amplifier a97
Have you tried the Kenwood website they might have a PDF of the instructions you can download for free? Providing it's not too old.
Jan 30, 2017 | Kenwood Audio Players & Recorders
Protect subwoofer showing on power amplifier
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Feb 03, 2014 | Sony MUTEKI HTDDW1600 Theater System
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
Error code e02 kenwood amp on sony xplode 1000 watt subwoofer box
It is possiblethat the amplifier had encountered a fault with a higher current drain whichhad triggered it to a protection fault condition. The fault can be with youroutput drivers. Please check for short on the outputs fitted for both the channels.Use a meter after disconnecting to check for short in the drivers. Disconnectthe positive and negative voltages to the output and see if the protectchanges. Even a fault in the preamp stages that drives in high current into theoutput can shut the Amplifier. Sometimes this can be a noise which can be a HUMor HISS before the protect works. Faulty capacitors in these circuits also cancause similar issues and needs close observation.You need to confirm andreplace the specific stages or outputs. If not there can be issues in themother board. Maybe the protect circuit by itself is shutting off due to afaulty bias or there is a leak in any voltage/current sensing circuit. Alsodisconnect the speakers and test, if the amplifier comes out of the protectmode then check for short on the speakers.
Jul 04, 2012 | Kenwood Car Audio & Video
There's a problem with my Kenwood vr-506 the power
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 22, 2011 | Kenwood Audio Players & Recorders
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Can kenwood ge970 be used with any amplifier?
you need to go to the electronics store where you can buy them, Ask the guys or gals there, what's up. No one on here can tell you that.
Apr 23, 2009 | Kenwood Unity System
Power problem amp
Sounds like its going into protect mode-try disconnecting the speakers from the amp entirely and turn the system on if it stays lit up- then ya know its the speakers (one of them at least) thats making your amp shut itself down. If thats the case look into replacing the speaker thats causing the problem.Also make sure that you have sufficient wiring to your amp - at least 8 gauge if you can. check all terminals /power/ground make sure everythings connected tight and not grounding out anywhere
Mar 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
My kenwood a97 hi fi amp has gone into protect mode a resistor is broken how do i get a diagram to identify the type i need
in my a-97 amplifier was the chip stk350-030 broken. I replaced it and it works again. The stk350-030 you'll find in the middle. Open the hood and cut the bottom (sound weird but its true)
Aug 01, 2008 | Kenwood Audio Players & Recorders
247 people viewed this question
 Grubhead
Grubhead
