Question about Samsung Televison & Video
I cant turn on the tv but the timer button is lit up I think its a fuse or bulb can you solve this issue
  • Samsung Master
  • 5,138 Answers
What is the Model# that is Printed on back of TV?
Posted on Nov 13, 2010
When i turn my tv on,after like half minutes tv turn off by self than starting turning on and off every half minutes....do you think is bulb problem or something als?thx
Symptom shows it is bulb problem that needs to be replaced too solve tv issue.
Existing lamp/ bulb in tv has reached an end of its working life span but still not dead/ broken and causing this problem.
Buy Sony original lamp for good picture and replace it.
Thanks.
Nov 04, 2010 | Sony (XL-2400) Projector Lamp for...
Timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Orange light re-set
Hold down the mute button on your remote and the
enter button on tv at the same time for a few seconds,
you should get a screen prompt asking if you want to
reset the lamp timer.
Mar 28, 2009 | Zenith E44W46LCD 44" Rear Projection...
Marker light working but turn signal not blinking
make sure the bulb is grounded good . usually if the front one is lit and the signal is fast the rear bulb might be bad . turn on the side that is not working properly and take off the lense and wiggle the bulb. also you might have to gt under it and check for the ground for the bulb .. holler if ou need more Jerry
Feb 05, 2009 | 2000 Oldsmobile Intrigue
I have a Samsung 52" TV. Last night all by itself the TV just went off. A red button right underneath power button is lit, says timer. I cannot get the TV to go on with the remote or manually. Do...
If this red button is lit is it flashing? If it is count the flashes and the gap between them as it is displaying an error code to you. Usually when a tv is stuck in standby or dead the first place to check would be the power supply board. Check all the diodes first as I have found that a faulty one can do many strange things. If you are not able to check this yourself please do not try find a competant technician. Hope this helps.
Sep 29, 2008 | Televison & Video
Mitsubishi WD 52528 tv
I had the same problem last year - it was, indeed the bulb. At the time the tv was still under warranty and Mitsubishi sent me a replacement bulb.
Dec 27, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
No Picture, Not Convergence Board Problem
PVAT! Give a real close look at the signal pcb for evidence of coolant leak.That will pull down power circuits, giving all kinds of strange symptoms.
Oct 07, 2007 | Samsung HCM4215W 42" Rear Projection...
Does not turn on
the unit has an internal timer , this has happened to me several times  , i changed bulbs thinking that was the problem , when the bulb timer reaches 2000 hrs or the if you change bulbs and dont reset it the machine will not respond , check your manual and reset the timer
Oct 07, 2007 | Sharp XR-10X Multimedia Projector
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
