Question about Hamilton Beach 80374 Custom Grind Deluxe Coffee Grinder
I lone the grinder but the the top plastic cup is cracked and it won't stay on. Can I buy the cover separately?
2 Suggested Answers
martineznoe8
  • 92 Answers
SOURCE: The clear plastic cup/lid for
CALL 1800-4MY HOME PROVIDE MODEL NUMBER THEY WILL FIND YOUR PART..
Posted on Feb 18, 2011
Which one is better a coffee bean or ground coffee?
if coffee is prepared with fresh grinder bean then it gives ultimate taste to coofee with perfect aroma. Some top-range bean to cup models have integrated bean grinders to do this for you, or you can buy a separate grinder. If you grind beans yourself, you'll need to choose the extra-fine setting for espresso brewing and make sure you thoroughly clean and maintain your filters, to prevent them getting blocked. Get Complete info about the best coffee best coffee grinder here.
Sep 04, 2014 | Nesco Cr-1010-prr Coffee Bean Roaster, 800...
Kitchen Aid Burr Grinder
If the parts are not listed separately, the motor and gears are a completely separate assembly. A replacement motor (assembly) would include the gears
May 06, 2013 | Kitchen Appliances - Others
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
I CANNOT REMOVE THE GRIND BASKET TO CLEAN IT.
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
a little cooking oil on the shaft before you insert the grinder will help, spray on pam works well and is easy to do...
Jul 01, 2009 | Cuisinart Thermal DGB-600 Grinder
G E /Walmart Coffee maker/ Grinder Model # 169082
The grinder parts have to be in place and the lid closed or it will not work. The plastic cover to the grinder twists to the left which engages a small switch. Hope this helps!
Aug 05, 2008 | Coffee Makers & Espresso Machines
Lots of disturbing noises, no coffee
It is is easy, if you know how to do it... as always
First take of the wather, trach bin etc,
Start with removing the cup wher the beans is stored, the adjustment knob for the mill is a tricky part. Remove it by bending out the side of the knob. Thereafter remove the screws from cup and those you on see on the top.
The front (silver frame) is removed by lifting it upwards, behind it you have 4 screws that has to be removed.
The last two screws is found under the wather tank.
Now you should had take away 11 screws, at least...
Bend the back of top and it will be off. Finally push the rest of the plastic cover backwards.
Do you know what the error codes says? I have know 6,8and no coffy...
May 11, 2008 | Krups Small Appliances Espresso Machine
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinder will not shut off
try passing air in the switch they sell air compress bottle to clean the computer pass that maybe water when on grinder switch dry hope it work cheers
Jan 29, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Hamilton Beach 80374 Custom Grind Deluxe Coffee Grinder Logo
59 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
