Question about Denon DN-S3500
UCD-70. CD Tray will not open. I have taken the casing off and everything works fine -EXCEPT, that I have to assist the top cover to lift so that the tray runs out. Any remedy?.
  • edward_dexte Nov 15, 2010
    Suggested solution began with the words "Problem with Denon DN-3500." The "solution" didnt seem to fit with my problem on UCD-70.
    Not really - but as luck would have it, the problem seems to have resolved itself.
  • Denon Master
  • 6,993 Answers
your is having a mechanism problem. Mechanism faults are hard and sometimes impossible to fix except a replacement is made. Also, I don't think there is a replacement part for UCD-70 mechanism.
So, what you will have to do now is to check any local repair shop within your vicinity, and ask if they have any bad UCD-70, so that you can remove its mechanism and replace it yours.
This is one of the remedy, there are still other remedies.
Good luck.
Posted on Nov 15, 2010
Try replacing the drive belt from the motor to the eject mechanism see " src="blob:http://www.fixya.com/da2bc957-4d91-4e18-bd11-11a3d3e5905b" alt="Faulkner_Michael_28_05_2018.pdf" type="application/x-apple-msg-attachment" style="caret-color: rgb(0, 0, 0); color: rgb(0, 0, 0); font-family: ArialMT; font-size: 13px;">
This gets worn and perished over time. Mine started working sporadically and finally jammed completely but after replacing the belt was good again
Posted on May 29, 2018
Rajesh: i need your help.
I Have the same problem, and the tray of my ucd-f07 doesn't open.
could You tell me when e is the hole where i should push?
is posible that i could send a interior cd photo?
waiting for your news
Posted on Jul 26, 2014
  • 656 Answers
Remove the cover by removing the screws now you will see the tray you will see a small hole below the tray use a long thin needle and push it in the hole down the tray it will eject from the lock now pull the tray to full length now connect the power and open close the system manually the use the open/close button in some case the tray might get little tilted look for any bend try it softly this will help you to clear the tray fault also check whether the power to the is working with out power the CD tray doesn't work
Posted on Nov 13, 2010
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
UCD 110 - Doesn't recognise every CD and will only play some CDs. I've tried cleaning the player with a CD Cleaning disc but to no effect.
I've had the same problem with a denon ucd 70,had the laser replaced and still the problem remained.Finally it appeared that a little wheel which moves the laser over the disk was broken and therefore the entire system finally couldn't read any cd anymore It started with some cd's however.
Still looking for a replacement wheel and fear that I have to buy a full new laser unit
Sep 24, 2009 | Denon Audio Players & Recorders
Tray is jammed. stuck part way open and won't seem
same problem with me... did u managed to resolve??
Sep 03, 2009 | Eclipse (AVN7000) Car DVD Player
Dvd rom will not work
The cover is warped. There needs to be just the right tension on the arm that lifts the eye of the drive to read disks properly try pushing down on the cover when you have it apart. So that you bend it alittle.
Aug 03, 2009 | Microsoft Xbox 360 Console
The tray will not open and cover on front came off
Try to locate an authorized dealer closest to you & if still under warranty it should get replaced free of cost, except for the cover. If not under warranty now look up in the net for the nearest Authorized service center and contact them via telephone first and foloow their advice. The tray & the cd/dvd drive may require to be replaced..............sodeep
Jun 03, 2009 | iLO DVDRH04 DVD Recorder
75 ohm antenna connection ''disappeared''
My antenna connector came off as well. After removing the two screw fron the back (on top), open the CD cover and remove the large screw at the front of the compartment. Now flip the unit over with the front of unit toward you. Insert a small flat screw driver between the cover and the botom on either side. There are two large tabs (either side) on the botom. pry away and up. Flip over and remove the cover. Careful of the ribbon cable inside, it is long enough to lift and flip the cover.
Nov 13, 2008 | Bose Wave Radio
Tray won't open, no buttons work
Return it. do not open it up or you will void any warranty. There is either a disconnected cable or a logic/power problem. In any case, a new piece should work out of the box.
Dan
Apr 10, 2008 | Numark MP-102 CD Player
Just asking.
I have the same problem. If you hear the motor opening, gently lift the tray at the appropriate time. It works for me.
Jul 13, 2007 | Zenith XBV243 DVD Player/VCR
Denon DN-S3500 Logo
829 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
