Question about Transcend StoreJet 320 GB USB 20 Hard Drive
I have a 320 USB External Hard Drive i store the data it is fine but when i try to copy the file from external hard disk it is getting an error "Cannot Copy CZ9EXML" & it will disconnects i have reformated 2 times but no use
    Brigadier General:
  • 10,406 Answers
> cannot copy CZ9EXML
Is this a file currently on the disk-drive? If so, then the blocks on the disk-drive "owned" by the file have gone "bad" -- those blocks cannot be correctly read.
It's a little surprising that a "full" FORMAT did not detect those blocks as being "bad", and mark those data-blocks as "never-to-be-used".
Avoid trying to read that file.
This might be an "early" indication that your disk-drive is going to fail.
Do *NOT* keep the *ONLY* copy of your files on the Transcend!
Posted on Nov 14, 2010
External hard drive format recovery
Install ReclaiMe file recovery from www.reclaime.com in your computer connect the hard drive and you will see the disc the way it was before. With a few clicks you will recover your files.
Dec 22, 2014 | Western Digital Elements powered by WD 320...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
I dropped 500gb verbatim external drive. It wants me to format the drive. How can i get the data back before i format it? Please help Thank you
Because the first few records stored on the disk-drive have been corrupted (or are physically unreadable), you get the "please format" message. Hopefully, the other 99.9 percent of the data-blocks stored on the disk-drive are OK.
Search online for 'data recovery' software -- it reads through the disk-drive, block-by-block, trying to merge blocks of data back into files that can be copied onto your 'C:' drive.
Sep 17, 2010 | Verbatim External, USB 2.0, 750GB...
I have a Simple Tech (simple Drive) 320GB external hard drive.the light comes on But my computer won`t recognize it. The light comes on but that`s it.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Jun 12, 2010 | SimpleTech 320GB SimpleDrive External by...
The computer no longer sees my 320 gb hard drive, do i need to download new drivers? if ao where do i find them. i store all my photo's and music on this hard drive
Possibilities:
1. dead USB port on your computer -- try another port
2. try a different USB cable
3. try your external drive on some other computer, to see if it works at all
4. open the casing, and separate the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive, thus bypassing that adapter, to see if the adapter has failed, or if the disk-drive itself has failed
5. Google-search for a commercial "data recovery service" -- such companies can disassemble your disk-drive, and fix it, just long-enough to copy all your photos/music onto a brand-new disk-drive.
Jan 25, 2010 | SimpleTech 320GB SimpleDrive External by...
My wd3200me was working now not
Try connecting to a different USB port on your computer.
Try a different USB cable.
Try connecting it to a different computer.
If it still does not work, either:
* the USB-to-disk-drive adapter has failed
* the disk-drive has failed
If the former, open the case, and remove the disk-drive,
and temporarily connect this "internal" disk-drive as a "slave" disk-drive into any desktop computer, and copy all the files. Or, remove the disk-drive, buy a new "empty" external-adapter, and install your disk-drive into the new case.
If all else fails, search online for "Data Recovery Services".
These type of companies are expensive, but they can "recover" files from almost any hard-drive that has "failed".
Jan 02, 2010 | Western Digital Elements powered by WD 320...
WD external Hard drive 320 GB hangs my computer everytime connect
Try the external hard-drive in some other computer.
If it still causes problems, then it is the external hard-drive, not your laptop, that has the problem.
If the warranty on the external hard-drive is still valid,
exercise the warranty to get a replacement.
If the warranty has expired, you could try to "disassemble" the casing, to remove the "internal" hard-drive that is "inside" the casing.
Then, connect that hard-drive to a desktop computer,
and copy your data to the 'C:' drive (or burn your data to CD/DVD disks), if you can -- it's possible that the "electronics" that convert the USB-interface to the hard-drive interface is the problem, and that your data on the hard-drive is perfectly OK.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
Usb external hard disk problem
try going into the command prompt
start --> run --> cmd
type chkdsk /R drive:
where drive is the drive letter e.g. chkdsk /R f:
This can take a while but on a number of occasions is has saved an operating system and data.
Make sure if it works you copy the files immediately and get a new external drive
Dec 29, 2008 | Western Digital Elements powered by WD 320...
Transcend USB is not working.
Dec 23, 2008 | Transcend USA 120GB Storejet 2.5" SATA -...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Transcend StoreJet 320 GB USB 20 Hard Drive Logo
267 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
