Question about Ovens
What to use to glue glass on Candy Oven Doors ?
Evo-Stick and other manufacturers make high temperature silicone sealant which resists up to 260C, this product is available at hardware shops such as Woodies or B&Q at Euro 9.95 for a 310ml tube.
Posted on Aug 05, 2013
    Problem Solver:
  • 18 Answers
You need a specialist high temperature glue - one that works on glass.
Try the oven glue provided at ovendoorglue.co.uk they also have a website in the USA ovendoorglue.com which ships worldwide.
Posted on Nov 13, 2010
Hi have taken screws out of oven door to clean on my Omega Oven & the whole front glass panel came off, can you please advise what glue is to be used to put it back on again please?
In my experience there is new glue used on oven doors. The glass has either a neoprene, woven glass matting or asbestos sealing gasket on the edges or both surfaces of the glass. The glass is put in place between clips/guides and then the door halves are tightened and it pinches the glass in place. The only glue-like substance you could use is Fire clay cement.
Jan 20, 2018 | Ovens
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
I need some help please, The bulb has gone in my oven! how do I change this and where would I get a bulb? The oven is a candy and the model number is FPP403.
Most ovens use appliance bulbs that can be purchased at any home improvement store. Open oven and locate the glass protective cover and remove it. Remove bulb and replace w/new one, place protective cover back.
Apr 23, 2011 | Candy F248P Electric Single Oven
Glue oven safety glass
You need a high temperature silicone adhesive specific for the job. No point using epoxies, they will not give you a long term solution and you will waste time and money.
This company makes a glass oven door repair kit that will do the job for you.
Feb 22, 2010 | Hotpoint SY21 Style Line Gas Single Oven
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
I have recently moved into a Park Home that has a 4/5 year old Candy cooker - the light bulb in the oven has failed and needs changing, but I cannot mov e the glass cover at all, it will not lever/unscrew...
If it has not been removed for a long time, then it could be stuck with bunt on grease and fat.If it is a round glass, then it should unscrew anti-clockwise.
Try wrapping a cloth round a pair of grips, and try to unscrew it that way.
Do not put too much pressure on, as you may break the glass.
Feb 08, 2010 | Candy FP855 Electric Single Oven
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Inside glass fell out , how do i glue it back.
Everflex Heatmate
Temperature Resistant Glue upto 300 degrees c
Apr 24, 2009 | Zanussi ZBF360X Electric Single Oven
Ovens Logo
186 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
