My hotkeys are disabled - Computers & Internet
Asusr5o3u keyboard wont work
there may be many reasons:- (i) your keyboard may be disabled.
sol- there are few hotkeys to disable both touchpad and keyboard. you may have pressed that hotkey and your keyboard disabled. if you will press that key again then it will be again enabled.
(ii) your keyboard's internal chip may be dead.
sol- you have to claim it's warranty to get it repaired.
(iii) your keyboard's drivers may be corrupted.
sol- sometimes keyboard's drivers are crashed due to some reasons. you can download new keyboard's drivers from its manufacturer's website. driver size will be nearly 100 to 200KB. also you can restore all keyboard default settings from device manager.
(iv) your keyboard may be damaged.
sol- no way to repair, you have to change your keyboard.
Apr 11, 2013 | ASUS R503u-rh21
On-screen keyboard problem
I think you might have your Hotkeys on, try disabling them
Hotkeys will only work while the SmartNAV software is running. Keyboard keys assigned to Hotkeys will not perform their normal keyboard function while they are being used as Hotkeys. For example, if the CAPS LOCK keyboard key is assigned to Left Click, it will only perform Left Clicks while the SmartNAV software is running. It will resume performing the normal CAPS LOCK function when the SmartNAV software is closed, or if the Hotkey is re-assigned or disabled.
please see the following link for more info
http://www.naturalpoint.com/smartnav/support/manual/sn-Chapter_4.html
May 12, 2008 | Apple MacBook Pro Notebook
How can I disable the Fn key?
Hi!
I will not ask why you want do disable the Fn key, but most questions regarding the Fn key are on how to get it working.
To disable it, you may want to uninstall any drivers related to HOTKEYS or FUNCTION KEYS (the name depends on your laptop type).
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Computers & Internet
I'm playing a game that uses tab key a lot. The dvd hotkey is right next to the tab and it tries to load that over my game. How can I disable that hotkey. The program came with the computer and I...
Uninstall the hotkey software from Control Panel (Add/Remove Programs in XP, Programs and Features in Vista, 7)
Alternatively install Startup Control Panel and uncheck the program from startup.The program works great in XP, for Vista and 7 there is more playing around:
  • Download the zip file
  • Click Extract All files
  • Right click on the program
  • Choose Run as Administrator
  • Install the program
  • Open Control Panel and choose Classic View
  • Run Startup
  • Uncheck something in HKLM and it will duplicate
  • Close Startup
  • Wait for Windows to pop up a box
  • Click Reinstall using recommended settings
  • Allow the program to run
  • Now you can remove the programs from startup.
  • Restart your computer
Jul 23, 2011 | Computers & Internet
I have a ASUS K40AF VX019R NOTEBOOK. It was infected with disabling virus that I have to have it reformatted. My problem is that I can no longer use the hotkeys of the keyboard. How will I reactivate...
I cant post the link here because its javascript.
Goto support.asus.com and in the search bar to your left, type K40AF and select All from the Category menu. Click search and select the product from the search result. Choose your OS, and install the drivers for your hotkeys. One of them will enable them.
Cheers.
Mar 16, 2011 | ASUS m6n Notebook
Hotkey volume not working
The utility for it may not be running, as it may have been disabled on startup.
Press windows key and R Type msconfig and press enter under the startup tab, check ati hotkey manager or something similar to that. Restart
Dec 30, 2009 | ASUS Eee PC 1000H Laptop
How do I fix the hotkeys for the brightness function
you may have disabled them from running at the start up try msconfig and find in the start up if there is a option for the hotkeys
Nov 22, 2009 | Sony VAIO PCG-K23 Notebook
Unable to use CD rom disk drive on Acer 5315 2142 model. Can PF Keys or Hotkeys be used to enable CD ROM disk drive? Disk drive was manually disabled by Device Manager. However, this happened while I was...
There are no hotkeys that disable a CD.
I'm thinking that your problem is that the CD has gone from the registry.
Download and run CDGONE. Here is one source:
http://www.geekstogo.com/forum/CDgone-file8.html
Sep 17, 2009 | Gateway MX6447 Notebook
I have to hold down keys for 2-3 seconds to type. How to correct?
It might be due to a service called "ATI Hotkey Poller" running
which is intermittently slowing the keyboard typing down.
To disable it in Windows XP Home:-
Go to Start->>Run->>type "msconfig"->> click the "Services" tab->> uncheck Ati Hotkey Poller->> Then Ok, then Restart computer.
hope this helps
chris
ziraffa@hotmail.com
Dec 15, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
