Question about ViewSonic VX2235WM Monitor
I cannot install the driver for Viewsonic VX2235wm (XP pro) Cannot select 1680x1050 res for this monitor
  • 1,719 Answers
Well your LCD supports 1680x1050 resolution.
You have to check the video/ graphics card of your PC, if it supports the same resolution or not. Let me know the model no. and your motherboard details for a better assistance.
Looking forward for your response
CreativeTECH
Posted on Nov 13, 2010
I am attempting to use a Viewsonic VX2235wm 22 inch LCD monitor with my Alienware m11x Rx2 laptop. (4g DDR3, Core i3 520um, Windows 7 64-bit) as an extension ofn my desktop. Naturally I would like to use...
Does it do the same if you hook it up to the desk top PC?
Common problem in this VX series are due to bad DC filter caps which can cause a lot of starnge symptom, see pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
The power supply may not be stable enough to handle higher resolution mode.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | ViewSonic VX2235WM Monitor
I bough the LCD model VA2231w- LED every time I turn it on then it pop up that change the resoluyion to 1920/ 1080P I don't know how to do it. So please help. Thanks Thai Nguyen
This would be the Native resolution. That your display functions and displays best in.
Windows XP, Vista and Windows 7.
(1) RIGHT mouse click over your desktop.
Windows XP will differ - but same basic idea to navigate and make this fix.
Pictures show from a Windows Vista Machine (extremely similar to Windows 7)
(2) Click Display settings
(3) Now you'll see a slider bar, Native Computer Display 1680x1050 resolution.
Some computers can not support this resolution and may cause non operational situations.
If the display setting is not on the slider bar. Chances would be that it's not a supported Resolution.
"Older computer" If the display doesn't show while trying different resolutions - do not click apply and wait. the screen will return to it's previous setting. ViewSonic VX2235 has a Setting that could be used to Disable this annoying message - Revert to ViewSonic lightdark_2.jpg
Nov 15, 2010 | ViewSonic VX2235WM Monitor
I connected my ps3 to my viewsonic vx2235wm and it says out of range or wont have a picture
The PS3 video output setting is too high for the monitor to handle, native resolution for this Viewsonic is 1680x1050. Try running the PS3 at 640x480 first and start changing the resolution to higher level.
Mar 25, 2010 | Computers & Internet
Monitor display wont go higher than 1280 x 720
if your system installed the correct driver to the new monitor or used a dafault driver to run it, this is what you want your system to do to run your old monitor. un install the driver from your system and remove the drivers to a temp folder. reinstall monitor to use a default driver to check it.
if you have the original install disk use that driver instead.
I'm not a advocate of automatic windows updates. if it works fine leave it be.
AndystUK
Aug 30, 2009 | ViewSonic VX2235WM Monitor
I need sofware of my viewsonic
The links below are two picture of the CD came together with the viewsonic monitor.
http://i590.photobucket.com/albums/ss341/VHC08/VX2235CameraAssistantSoftware.jpg
http://s590.photobucket.com/albums/ss341/VHC08/?action=view&current=VX2235Driver.jpg
If you happen need the driver only viewsonic.com has it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.viewsonic.com/products/archive/vx2235wm.htm
X2235wm User Guide, English PDF: 513KB
The CD contain Camera Assistant Software is only 18M, which is an executable file. The software is not too impressed to me. The other CD is the driver disc. It also has a pdf owner's manual and the Adobe reader 4.0
View More Drivers/Utilities »
Jun 03, 2009 | ViewSonic VX2235WM Monitor
Can't set 1680x1050 resolution on viewsonic monitor
I found the solution for my problem.
Initially I thought it's a monitor problem and was trying to find the drivers for it.
The problems is not with my monitor but with the video adapter I use.
My video adapter has a intel chipset (Mobile Intel(R) 965 Express Chipset Family). Apparently the driver that I was using was quite old.
The only thing I had to do is:
1. Download the latest video adapter driver
2. Uninstall the current video adapter driver
3. Restart the system (Windows XP)
4. Install the new driver.
5. Restart the system.
May 19, 2009 | ViewSonic VA2026w Monitor
I just bought a viewsonic vx2240w. When I change the resolution to 1680x1050 the page becomes too wide for the screen. I have to scroll left and write just to see it.
This sounds like an issue with the windows driver for your video card. I have to load the viewsonic driver for my monitor first and make sure the device monitor is showing the vx2235 and not default monitor. Then make sure your video board will support the 10 x 16 format and check for any settings about horizontal scrolling. If you are running an ATI card, get the latest version of the Catalyst drivers from their web site. Hope this helps.
Feb 02, 2009 | ViewSonic VX2235WM Monitor
Hi i have big problem with my ViewSonic VX2235wm monitor
check did you insert external display card or using internal if not inserted then internal display card will not support above 600x800 if you want to work with high resolution then insert AGP card and reinstall drivers there are 4 type cards 1x,2x,4xand 8x you use 8x AGP card then select high resolution also you can look best movie and good support to 3D games
Nov 18, 2008 | ViewSonic VX2235WM Monitor
Cannot get correct resolution
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Jun 04, 2008 | ViewSonic VX2235WM Monitor
Monitor resolution
when you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Feb 15, 2008 | ViewSonic VX2235WM Monitor
ViewSonic VX2235WM Monitor Logo
228 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
