Question about Dryers
Everytime i go to start dryin clothes it trips thr electric its a condensor dryer thanks
    Problem Solver:
  • 25 Answers
Jhfgjhnvbhjnfgjhn
Posted on Nov 13, 2010
Not heating
If you can hear the dryer start and operate but at end of cycle your clothes are wet then it is likely (assuming the heater is turning on) that the fluff collection on the condensor unit is blocking its operation.
Refer manual at this site and follow instructions on page 20.
http://www.eirvik.is/gogn/L/t233c.pdf
Apr 19, 2014 | Miele Novotronic T230C Electric Dryer
Hotpoint TCL 780G condensor tumble dryer
hi make sure heater element is not touching back of dryer causing a short or break on wire catching casing
Mar 05, 2014 | Hotpoint Dryers
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
My dryer not heatin up and dryin clothes hotpoint aquarius CTD00
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
We have a full video library on appliance repair video’s
Dec 30, 2009 | Hotpoint Dryers
Burn streaks on clothes from dryer. Sometimes items get stuck inside dryer I have electric model 417 81142000 model
it sounds like thr rollers are shot that hold up the tube and mkes it role around,they need to be replaced, if more imfo. neede cotact elffender@ yahoo.com, hope i can help, thank you.
Dec 29, 2009 | Kenmore 62722 Electric Dryer
Dryer runs but clothes never dry. Water is not collecting in plastic tub
Same problem. You need to empty the condensor. Take the bottom panel off the front of the unit. Place a LARGE towel under the dryer to catch all the water that is going to spill out. Move the 2 red tabs to the right & SLOWLY open the panel. Allow the excess water to drain into the towel, then fully open the panel. Have a bucket handy to catch the water as you remove the condensor. Slide the condensor out & drop the back end into the bucket to catch as much water as possible. Then take the condensor to the laundry tub & rinse it out thoroughly. Re-assemble. Next time you switch the dryer on, just check that you get a short burst of water from the drain hose. You will probably have to do this every 5-10 loads.
Oct 19, 2009 | Asko T721 Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
