Question about Canon MV650i Mini DV Digital Camcorder
Cannot get cassette out - Canon MV650i Mini DV Digital Camcorder
    Problem Solver:
  • 25 Answers
Jhfgjhnvbhjnfgjhn
Posted on Nov 13, 2010
How do I remove the cassettes or cassettes from an Elna 7000? It stopped working after a power surge. I bought a used machine that works, but it doesn't have the 2 cassettes with the extra stitches.
The cassettes have a little tab you pull on which folds flat afterwards.
Disconnect from the power.
Open the cassette cover on the right side with a coin or with a screwdriver. Free the opening to the cassette housing by moving the slide downwards for inserting the upper cassette and upwards for inserting the lower cassette. (to insert, fit the cassette gently and firmly into its housing and fold the tab flat.) You will need to reverse to remove them. I've got a feeling they can get pretty firm when they have been in there for years, most people would add the extra cassettes and never remove them.
Aug 15, 2015 | Elna Sewing Machines
How do you remove sramxx1 cassette
a xx1 cassette is removed in exactly the same way as a normal cassette
Apr 24, 2013 | Bike Parts Express SRAM XX1 10-42 11 Speed...
My heads on the xm1 seem to be dirty, ive used a sony cleaning tape, it only makes a difference for an hr or two taping, any sugestions
Firstly, I must explain how the MiniDV system works:
Although this may sound illogical, MiniDV camcorder heads do actually use a type of lubrication cassette system and there are 2 types:
- DRY lubrication (Canon, Panasonic, JVC etc)
- WET lubrication (Sony)
Now, if you haven't noticed already from the above 2 types, you are in fact using the WRONG type of cassette on your camcorder.
Although Sony cassettes are often readily available (and often perceived to be the best quality), by using Sony cassettes on a Canon camcorder (or Pana, JVC for that matter), you are in fact causing premature wear on the heads. So, the condition you are describing as 'dirty' heads, is in fact caused by the use of the wrong (wet type) cassettes on your DRY type camcorder.
Using "WET" type cassettes on a DRY system camcorder, can often leave residue on your heads, or worse....cause wear. The same principle applies to Sony camcorders - use only Sony 'WET' type cassettes, not Dry cassettes.
This also applies when using HEAD CLEANER cassettes - as indicated, you have used a Sony Head Cleaner cassette (this is a WET type cassette), when in fact, you should be using a DRY HEAD CLEANER cassette (Pana, Canon etc).
CAUTION: when using a head cleaner cassette, only playback the cassette for no more than 6 sec's at a time (anymore will damage the heads).
Summary:
For your Canon camcorder, use only DRY MiniDV cassettes (Pana offer cassettes from Studio, Professional to Master Quality), including DRY Head Cleaner cassette. This should improve the playback quality from your camcorder.
Mar 25, 2010 | Canon XM1 Mini DV Digital Camcorder
Canon gl1 camcorder dead pixel and artifact when
I know this camera well !
This is likely to be your heads, but you need to be made aware of the following:
1) MiniDV cassette
The quality of your cassettes should first be considered:
Panasonic, Canon and several other brands use what is called "Dry Lubricant" cassettes. For this reason, you should AVOID at all costs, any cassette made from a manufacturer whose cameras use Wet Lubricant type cassettes. Unfortunately, this means you should AVOID SONY cassettes (as Sony cameras use the WET lubricant system).
Dry type cassettes also cause less wear on your heads.
I would highly recommend you use only Panasonic PQ (Professional), SQ (Studio) or MQ (Master) quality cassettes.
(PS: I use these Dry type cassettes on my Canon Pro Camera)
2) Camera HEADS
As stated in above (re the cassettes), if you have inadvertantly used a WET type cassette in your camera (i.e. Sony or similar), have been using old cassettes or debris/dust has entered the compartment, then there is a high probability that some microscopic contaminants may have fouled your heads.
If so, your heads will require cleaning.
The good news is, Panasonic have a MiniDV Head Cleaning cassette (DVMCLA) which can be purchased for around $8 - $15. (try Amazon.com).
If you choose to use this cleaning cassette, it is EXTREMELY IMPORTANT that you only run the cassette for a max. of 5 seconds ONLY, for each clean (and no more than 10secs, as using this cassette longer than stated, can cause wear). Then, try playback of your old cassettes to look for improvement. Cleaning is only necessary, if you experience drop outs on dry type cassettes, or pixelating of picture playback.
If this head cleaning process does not resolve your problem, then you will require professional assessment.
Good Luck !
Nov 24, 2009 | Canon GL1 Mini DV Digital Camcorder
The DV tape is totally macroblocking during playback. Is this an indicator of dirty heads?
I've just posted this solution to another user:
1) MiniDV cassette
2) Camera HEADS
Good Luck !
"if this has helped you in any way, please rate this solution"
Sep 24, 2009 | Canon GL1 Mini DV Digital Camcorder
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. small_note.gif black_dot.gif If the paper is curled, uncurl it before placing it in the cassette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets of 20 lb bond (80 g/m2 ) paper.
  3. Load the paper stack beneath the cassette's length guide (1) and width guide's claw (2).
    load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do so will cause a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. black_dot.gif Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert the cassette as far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon imageCLASS D860 All-In-One Laser...
Cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon MV650i Mini DV Digital Camcorder Logo
116 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
