Question about Opera Software Browser
It says file is corrupt when i attempt to download it. Thank You.
    Problem Solver:
  • 25 Answers
Jhfgjhnvbhjnfgjhn
Posted on Nov 13, 2010
My eee pc is saying files missing or corrupt
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Windows 7 chkdsk http://www.w7forums.com/use-chkdsk-check-disk-t448.html Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. also download the registry cleaned cc cleaner
http://download.cnet.com/ccleaner/
You can also run a free registry scan using utilities from http://re7.info http://www.download3000.com/showarticles-182-0-date.html System Utilities. http://www.download3000.com/showarticles-178-0-date.html Optimisers and Diagnostics. http://advanced-systemcare.soft32.com/ One-Click Free System tool for PC tune-up and maintenance. Registry repair
Feb 06, 2013 | Computers & Internet
Corrupt excel sheet
MS Excel comes with an automatic recovery feature that attempt to reopen corrupt excel file along with repairing a file. If it fails to repair a corrupt excel file then try to open a file without repair. Sometimes this automatic recovery feature fails to open & repair corrupt excel files at this stage users can repair corrupt excel file manually.
To Manually Repair an Excel File: For manual repair of a corrupt excel file, you have to perform following steps:
  • Go-to the File Menu & click on 'Open'
  • Now select the file that you want to repair and click on the arrow next to 'open' button.
  • Click on 'Open & Repair' & any one method that you want to recover your data.
Source : Link
Jan 16, 2013 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
I deleted files from my RCA digital voice recorder a short time ago and I just downloaded a recovery system and recovered them, but when I try playing them unsupported file format comes up. What do I do?
this will happen if the files are corrupted, i would try using vlc to play them as that will attempt to fill in the corrupted parts so you will at least be able to hear most of what you recorded
http://www.videolan.org/vlc/download-windows.html
Mar 13, 2011 | Televison & Video
BDP-51FD Firmware Upgrade WILL NOT DOWNLOAD. IT SAYS THE FILE IS CORRUPT..
http://www.blu-ray.com/firmware/firmware.php?id=29
Attempt to get the file manually, if that doesn't work, try using the file in administrative mode before using it. If it is corrupt completely, delete it and redownload it.
Mar 13, 2011 | Pioneer BDP-51FD Blu-Ray Player
I have a Asus eee 1005HA running Windows XP. When I try to boot, I get an error message saying "file missing or corrupt \windows\system32\config\system You can attempt to repair this file by starting...
http://thepiratebay.org/torrent/5199210/WINDOWS_XP_PRO_32-BIT_SP3_ISO_ACTIVATED_GENUINE
download the bootable image file here, use torrent downloader to download
after download burn iso file (use burn image file) to cd, and you get windows cd installer
and you can use this cd to repair your computer
i hope this helpful
thank you for using fixya
Feb 05, 2011 | Computers & Internet
Failde to download.ini file
Three possible conditions possible. First, the media requiring download is corrupted. A source from the network would possibly display a nonexistent program attachment. A common message soon after download is display of an error ro corruption of what has been acquired on the computer. A disk medium being downloaded would display a download error when damaged.Second, a program already existing on the computer producing fail displays are corrupted either has been deleted or integrated by a malware software producing malfucntion. Third, the computer system on which attempting to download .ini. files could be incompartible with the file. An outdated computer system, or an outdated computer program, or a versions of compartibility of the system to the medium files displays the warning message produced.
improtant notes
1. Check the compartibility of the computer operating system with the media file attempting to be downloaded.
2 a compartible computer could require updates to function with the file
3. The .ini file could require decoding to produce a display on the computer
4. attempt to download on another computer version to check for compartibility
contact technical assistance if persistant
Dec 20, 2010 | Logitech Computers & Internet
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
Corrupt files
I feel that the problem you are having is because the firmware that is currently on the device is corrupted...i would recommend you to go to the sandisk website1.gif to get the latest firmware upgrafe for your device..the link for the firmware upgrade is below..I hope that helps...if you have any more problems please contact me....
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Please rate accordingly
Thank You
Computerrep
Apr 16, 2008 | SanDisk Sansa E280 MP3 Player
Opera Software Browser Logo
23 people viewed this question
Top Opera Software Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
mukhtar21 shaikh
mukhtar21 shaikh
danoyachtcap
danoyachtcap
Are you an Opera Software Computer and Internet Expert? Answer questions, earn points and help others
