Question about Mitsubishi WS-65513 65" Rear Projection HDTV
After a couple hours of operation, my 65513 starts switching video modes on its own. Standard to expand and back. The time between switches starts at around 30 seconds and drops to immediate after a few minutes. The only remedy is unplugging the unit for an hour or so. Turning it off, but leaving it plugged in results in it not turning back on after a while.
    Top Expert:
  • Mitsubishi Master
  • 74,136 Answers
Hello
You just reset your TV using reset button on the front panel of your, after it power On. The process is given below.
Press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green led will flash quickly for about one minute. When the green led stops flashing, you may turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button may lost, however, the changes you made previously are not lost. Only those changes since the
power On may be lost when the system reset button is pressed. All other settings are retained.
Posted on Nov 25, 2010
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Malfunctioning One-Touch Navigation & Joystick Control
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Sep 11, 2008 | Panasonic PV-GS300 Mini DV Digital...
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
Vcr panasonic NV-HD 660B When it is off and switch it on,works everything properly for about an hour.Then video cassett comes out and the error message comes-F03
You have a K-Deck mechanism. If you put "Panasonic K-Deck" into Google you should find further service information.
However I can tell you that F03 means that it is locking up as it unloads. The cause of this is listed as Load motor or drive, timing, mode switch. The fact that you have operation of it for some time shows it might be the mode switch. If it does eject normally at all, before it starts playing up also would point to the mode switch. You might get away with a spray of Servisol Video 40 on the mode switch. If not take care to remove it, as it needs to be set up correctly or it will create tuns of problems. You should be able to get one from Currys Partmaster.
It might look like this:
Oct 26, 2010 | Panasonic Televison & Video
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Athletic wrist watch stuck in 24 hour mode
    Maddening, isn't it? Fortunately the solution is here:
    http://www.ehow.com/how_5593310_set-athletic-works-watch.html
    1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
    4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
    Apr 30, 2009 | Watches
    The clock on my shelf system cx-naj20u went to 24 hour mode. How
    To switch to the 24-hour standard
    Press CLOCK while pressing SHIFT on the remote control and
    then press S within 4 seconds.
    Repeat the same procedure to restore the 12-hour standard.
    Apr 04, 2009 | Aiwa NSX-AJ20 CD Shelf System
    Timex 1440 sports digital watch time setting
    1. Press and hold the mode button until it starts to blink, then release.
    2. First the alarm time will come up.
    3. Press the mode button once to get to the time and date.
    4. The seconds will flash first.
    5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
    6. Press the lap/reset button to change the values.
    7. When done, press the mode button again to return to normal.
    Mar 09, 2008 | Timex 1440 Nylon watch
    Error message/Switching off
    Hi.
    What is the model number on the rear of set & chassis number if it has one.
    Oct 10, 2007 | Televison & Video
    Mitsubishi WS-65513 65" Rear Projection HDTV Logo
    26 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
