Question about Car Audio & Video
Speakers,fuses and radio working but no sound from the right speaker in ford ka
  • 44 Answers
Has balance setting or fader setting been messed with?
It is possible the speaker itself is blown and needs replacing.
Posted on Jun 21, 2008
Were is the fuse for the radio on a ford ka
the fuse box is normaly at the right side at the bottom near steering wheel,if nothing is rong the it can be that its got a fush on the radio it self at the back
Apr 23, 2011 | Car Audio & Video
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Jan 13, 2010 | Car Audio & Video
Ford ka radio not working no sound
need more info. Are you saying the radio does not come on or does it turn on and has no sound. Did it work before?
Sep 21, 2009 | Car Audio & Video
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
Is there any way of changing the balance on the radio casset on my 02 FORD KA as the right hand speaker doesnt have any sound coming from it
There should be a setting on the head deck, depending on what model it is. Try fiddling with all the bottons on it. If the balance had never originally been changed maybe you're speaker wires not connected up properly. If it has then you can definately changed it back, look for a setting called "bal" and make sure it's 0.
Aug 02, 2009 | House Brand Car Audio & Video
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Red - Ground
Speaker Connector:
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
There is no sound coming out the speakers
Check all the fuses in both fuse boxes.  If that doesn't help replace the radio.
Mar 25, 2009 | 1991 Ford Taurus
I own a 1993 Ford Explorer and my radio just stopped working. I checked all my fuses and they are all fine. What could be the problem
the radio may be defective, pull it out and verify power to the radio, u can buy the radio removal tools at any NAPA parts store or get them from Ford, they are very cheap to buy. here is the wiring colors and what they do, u will also need a cheap 12 volt test light, about $6
1993 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
Jan 08, 2009 | 1993 Ford Explorer Limited
My ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Jan 07, 2009 | Car Audio & Video
Car Audio & Video Logo
270 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
