Question about Panasonic Toughbook 48 Notebook
Upgrading memory cannot find memory slot (purchased on ebay, second-hand, no manual)
    Master:
  • 788 Answers
Open all the hatches underneath the unit, there is a chance that the only memory slot you find is empty as the current RAM in the system might be on-board or somewhere else. If none of the hatches under the unit reveal the RAM slot then it would be under the keyboard. On the toughbooks I use there is four screws above the keyboard holding it down. On your there may be a plastic piece that needs to be removed to reveal the screws or you may have to remove some screws from the bottom to loosen the keyboard.
Posted on Jun 18, 2008
  • Dean Joly
    Dean Joly Jun 18, 2008
    The location of the RAM may also be indicated by a picture of a microchip on the hatch in question.
Purchased two sticks of 1 G memory, want to upgrad...
Assuming you purchased the correct memory and you have two open memory slots it is very easy. Just open the computer case and look on the mother board for memory cards that look like the ones that you purchased. If there are two empty slots you just need to insert the cards into these slots (just ensure that you ground yourself before touching the cards or the mother board by anti-static band or at least touching something metal first).
When you boot up assuming the bios is fairly current should recognize the new memory and you should be good to go.
May 20, 2010 | Computers & Internet
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Where is the memory card slot in moto rokr e6
On the left side. Along the music buttons. There's a slot there where you see a picture of a memory card. Remove that cover and that's where the slot is.
Jun 17, 2009 | Motorola Mobility ROKR E6 Smartphone
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
I can't find the second ram slot
Lots of laptops have the second slot under the keyboard. If you are adventurous take the keyboard off and look in there.
Mar 11, 2009 | Evesham Computers & Internet
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Trying to upgrade the memory on my Acer Ferarri 3400 Notebook but can't find the location of the second memory module. The user guide says that there are two memory slots but there is only one under the...
THERES ONE MEMORY LOCATION R U UPGRADING BOTH CHIPS OR JUST ONE, MOST SYSTEM ONLY COME WITH ONE CHIP U HAVE TO ADD ONE IN THE SAME LOCATION TO UPGRADE OR GET THE HIGHEST SINGLE SLOT CHIP U CAN GET UR HANDS ON,I WOULD SAY CALL TIGERDIRECT AND TALK TO SOME OF THERE SELLS ASSOCIATES THAT WILL PROBABLY BE THE BEST SOURCE OF INFORMATION ON HOW THE SYSTEM IS CONFIHURED
Aug 11, 2008 | Computers & Internet
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
Acer TravelMate 272 Memory
I think in this case the second memory slot is under the keyboard.
Mar 17, 2008 | Acer TravelMate 272XC Notebook
Panasonic Toughbook 48 Notebook Logo
54 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
