Sound but no picture toshiba regza wlt66 - Televison & Video
SOURCE: No picture, just sound
No new video card required. I just reset the television by holding the on/off button for five seconds (yellow light on front panel blinks repeatedly). I then cycled power using the remote control and my picture came back. Worked for me. Hope it works for you.
Posted on Jul 16, 2008
SOURCE: Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
Posted on Apr 02, 2009
SOURCE: When switching on my 32c3035d toshiba regza lcd tv
i had the same problem with the same television, apparently it is a faulty power supply board.if you can remove the power supply board and send it to digifix at buxton they will repair it for you.Beast to contact michael at digifix tho and describe your problems as it may be something else.
Posted on Nov 10, 2009
  • 290 Answers
SOURCE: Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Posted on Jan 17, 2010
  • 8457 Answers
SOURCE: Toshiba REGZA 42
The 2 long boards call the LCD inverter boards are dead.These 2 long inverter boards help the LCD screen to have backlight to produced a picture.These 2 long LCD inverter board are dead,must be replaced to get a picture again.Tries websites like Shopjimmy.com,Ebay.com to buy these 2 refurbishes long LCD inverter boards for the replacement.
Posted on Jul 05, 2010
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
Dec 19, 2012 | Toshiba Televison & Video
32"toshiba regza no picture/ sound ok
lock for picture on the lcd but thi picture have to be very dark open it check for blown capacitators or blown fuses :D
Sep 22, 2010 | Toshiba REGZA 32RV530 31.6 in. LCD HDTV
Toshiba REGZA 42" 1080p Flat-Panel LCD HDTV I have sound but no picture at all?What could be wrong?
Jul 05, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza has sound but no picture.
Hello: One solution to see if the picture is there and you just don't have any back lighting is to take a flash light and shine it at the screen you if you see a faint picture in the background then the inverter boards has failed, and you have no back lighting. If you see no picture then more then likely the Main control board has failed or the power supply has problems.
Nov 08, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba Regza 42" lost all hdmi input
TV was on, screen went black... Stanley cup playoffs double OT continued sound only. TV now just clicks on and off.
Mar 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
Feb 17, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Jul 01, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No sound
have you checked the connections and what is hooked up to the tv do you use a receiver or surround station to produce sound and did this just happen? please more info.
May 27, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
