Question about HP Deskjet D1455 InkJet Printer
When I print it is toward the center, the whole right side is missing
  • HP Master
  • 1,719 Answers
Faded prints even after replacing the toner cartridge could most likely be due to dust at the laser reflecting mirrors inside the printers, which requires cleaning by a professional.
If you are comfortable with working inside such machines, you may do it your self. Download repair and service manual for your printer and study it before you attemp cleaning/ servicing.
Hope this helps!!
Let me know if any further clarification is needed.
CreativeTECH
Posted on Nov 13, 2010
  • Creative Tech
    Creative Tech Nov 15, 2010
    I regret the inconvenience faced by you due to my previous solution, which is not related to your printer. Hence, your rating of the solution is also correct.
    Actually, it was an error due to the fact that i was responding to a similar issue related to laserjet printer.
    For your HP Deskjet D1455 InkJet Printer, all i can suggest is to check the mechanical parts, like paper path, rollers and especially ink cartridges for their proper alignment. Also, make sure that the ink levels are ok.
    Moreover, the cartridges may require cleaning because if you dont use inkjet printer for a longer period of time, the print-heads get clogged. Cleaning can be done by using soft lint-free cloth and inject cartridge cleaners. Instead you may use warm water.
    Please note that APPLYING TOO MUCH PRESSURE CAN DAMAGE THE PRINTHEADS.
    Hope this helps!!
    CreativeTECH
My Datamax I Class is only printing one one side of the label, is there an adjustment I can make?
1. Right side not printing. Rotate round green knob (possible black center) found on right side of printhead assembly clockwise (or if necessary, through entire range) printing at each stop to check, until printing is satisfactory. If not fixed, next step is to do "Burnline Adjustment" as described in Operator's Manual.
2. Left side not printing. Make sure that large green plastic printhead latch on right is pushed firmly toward back of printer while printhead is pressed down, to make positive lockdown of printhead. Try rotating round green knob described in (1) above through entire range, printing at each stop to check. If not fixed, next step is to do "Burnline Adjustment" as described in Operator's Manual.
Nov 23, 2012 | Datamax I-4208 Thermal Label Printer
Print output on left hand side is missing
see if there is a local repair center, Sounds like the wiper on that side could be out of alignment. and hitting the drum early there for possibly wiping it before it has time to hit the paper and transfer it over.
Nov 09, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
My printer keeps jamming going threw the fuser what do you recomend I replace thanks
pull the drawer out and check to see how many fingers are sticking out of the paper size snap in plate on the side of the drawer. letter size is the 2 bottom fingers if there are more or different fingers check to see where the paper slide inside the drawer is set if its not perfectly centered in the whole for that size paper the wrong fiingers will cause a timming issue. if these are right
print the network page and see if it prints smaller than the full page or if its missing the solid line that forms the box around the outside of the network settings at the bottom of the page. if either of these is true then replace the paper size board located behind the logic board.
if all of these are right either the narrow media or the exit sensor on the fuser itself will be the cause
Nov 02, 2009 | Lexmark T630 Laser Printer
How do I change the oil on a 2002 fat boy? Where is the drain plugs?
On the fatboy, the oil drain plug should be on the right side, just under the frame, directly below the oil tank. The primary drain is on the left side under the derby cover on the bottom. The tranny drain is on the bottom towards the rear pretty much centered.
And, as our darlin' little miss piglet said, a maual is worth the investment.
Jun 28, 2009 | 2003 Harley Davidson FLSTF Fat boy
My officejet 7680 allinone printer misses printing black and smuges the paper
remove the black and see if there is any ink build up on it. look into the right hand side of the unit where the carriage rest on the service station and if you see a ***** of black ink then the unit needs to be cleaned out. USE A FLASHLIGHT TO SEE THERE
Oct 04, 2008 | HP OfficeJet d145 InkJet Printer
Printing error
the problem is with the printer. try to examine if the printer head is on the right side. the default must be on the right side. if you can't move the printer head towards the right it means it got stuck up. if you will look inside it you will see a 'rail like' object on the bottom of the printer you can push it down with any pointed object for the pinter head to get back to its original position. if this doesn't solve the problem look for the nearest service center coz the printer needs an alignment.
Aug 10, 2008 | Casio HR-8TMPlus Calculator
Typing
Your description was a little hard to understand, does the carrier not go left og center or does it just start printing at the center?
If it goes left but dosen't start printing till the center check to see if the platen (roller) is fully seated in the side frames.
If it stopps in the center reset the L. margin.
DickyO
Jul 11, 2008 | Lexmark Wheelwriter 1500 Typewriter
Brother MFC-240C
2nd first:
Yes. You should print a alignment test print and follow the instruction which is given on the test print.
I dont understand the first complain:
Do you miss several first squares or do you miss just one?
The latter one is no prob. You can ignore that. The first one (several 1. squares missing) is a serious prob: This indicates that a whole channel is defective!
Did you do a cleaning procedure and check the squares afterwards? If not do so. If you still miss the several 1. squares the ph needs relacement.
Dec 10, 2007 | Brother Multi-Function Center MFC-240C...
IBM Infoprint 1352 Laser missing an inch of test on the left hand side
could be, but first take out the cartridge then look inside the unit there is a black roller, kind of spongy or hard rubber, is the black part towards the right? grab it and give it a tug and see if you can SLIDE it to the left if so then it needs to be replaced, that is your problem.
It could also be the fuser, are the copies on the left coming out smudged or with a grainy shadow? then it's the fuser.
Oct 11, 2007 | IBM Infoprint 1352 Laser Printer
HP Deskjet D1455 InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
