Question about Kenmore Elite 45986 Front Load Washer
I get an F 11 code on the display - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 19,396 Answers
Hi.
F11 is bad connection detected between central control unit (control panel) and motor control unit(control module connected to motor, inside machine).
Try disconnecting power for five minutes and see if this can reset the error.
The repair is carried testing wiring between the two control modules and testing wiring to the motor.
To contact a repairer call the service number listed in the appliance use and care manual.
Regards.
Ginko.
Posted on Nov 13, 2010
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Dec 01, 2015 | Frigidaire Affinity ATF6000F Front Load...
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Dec 29, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Dead battery lost code to radio.how do i redo the
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
This tip originated from LOTZAHP
Jul 21, 2010 | 1996 GMC Jimmy
Unlock a chevrolet 2000 truck radio
Procedure:
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction in your Owner’s manual. Use the code from STEP 11 instead of your personal code.
Jul 13, 2010 | 2000 Chevrolet Silverado 1500
HP Designjet T1100 error code 08:11
The error code indicates a communications problem between the display and the electronics. Reseat the connectors on the display and the connection to the electronics. If that does not solve the problem, replace parts in this order until the problem is solved: display and display cable, electroncis module, logic board.
Apr 19, 2010 | HP Designjet T1100ps Printer
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
Mar 03, 2010 | Washing Machines
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
HOPE THAT HELP
Oct 20, 2008 | Konica Minolta DiALTA Di183F Copier
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Kenmore Elite 45986 Front Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
