Question about Panasonic TCL32X2 32 in. HD-Ready LCD TV
I recently bought 3 Panasonic TC-L32X2 TV's. I had them installed professionally. After only about 4 hours of TV time, one of the TV suddendly does not have volume. I tried unplugging it and plugging it back in. I tried unplugging all the cords and plugging back in. The picture is fine, just no sound..... Help!
  • 1 more comment
  • joylene6797 Nov 14, 2010
    I will try the firmware as I have already have it mounted and everything.
    The link does not work... can you report it?
    I put the download the firmware on a blank SD card. TV says cannot read file. I reformated the SD card using FAT then Fat32 no luck. Any suggestions?
    Thanks
  • joylene6797 Nov 15, 2010
    it is not under a folder. it downloaded as SDImage.bin
  • 4,889 Answers
Did you confirm that its not a problem with the video source? Did you try a different video source such as a DVD player? If yes and you still have same results then , its better to get replacement sets as they are still under warranty.
Posted on Nov 14, 2010
  • eagle338
    eagle338 Nov 15, 2010
    The firmware will come as a compressed zip file. You should de-compres it and then make sure that the firmware is not in a folder but on the flash drive itself. Example if it is in D:\frwupdate\update.bin you should move it to
    D:\update.bin
  • eagle338
    A file thats little over 5MB(5121KB)?
  • 10,594 Answers
There is firmware update available at Panasonic Support that will solve sound/ audio issue in this tv.
Click above link and download firmware update and follow given instructions strictly to update firmware of tv OR call Panasonic on numbers written on warranty documents for warranty cover as tv is new and would be under warranty.
Hope these info will help you.
Thanks.
Posted on Nov 13, 2010
  • Shahid Electronics
    Shahid Electronics Nov 14, 2010
    Link is valid and working.
    http://www2.panasonic.com/consumer-elect...
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Panasonic viera TC-L32X2 TURNS ON BUT IS REALLY DARK you can barely see anything what would be the problem
The backlights are probably failing. Your TV uses fluorescent tubes for light. The control boards that operate the lights are most likely giving you the problem.
Oct 24, 2016 | Panasonic 32" TC-L32X2 LCD TV
How Can I Reset Panasonic TC-L32X2 TV
I don't know on this model but my Sony has a Menu button on the top of the TV and I just pushed that and used the arrow buttons to move up and down the menu to reset the settings.
Nov 18, 2015 | Panasonic Viera TC-L32X2 32" 720p 1366 x...
Panasonic tc-l32x2x
I can very well understand how disappointing this is. But no company can ever do a free replacement for such causes. You need to have pest control in the house as the cockroaches can damage any electronic equipment from microwave oven to audio/video equipment in the house. If you do not do that, it will be Panasonic today and some other brand tomorrow.
Aug 22, 2012 | Panasonic Viera TC-L32X2 32" 720p 1366 x...
I cannot get sound when using an HDMI with my Panasonic Viera TC-L32X2 LCD. I have tried three different HDMI cables, I'm highly confident that is not the problem. My cable provider had to override...
Is this TV new or new to you? I suggest you check two parts of the Audio > Advanced Audio menu. First check if the TV speakers are set to on. Next check the HDMI audio setting. This should be set to Digital. (There is an analog option that works with DVI to HDMI cables and older HDMI cables that aren't fully HDMI compliant. For these situations, you connect an audio cable between the cable box and TV. I believe your audio cable needs to have a 3.5 MM (M) end at the TV and plugs in at the computer audio input.)
Since your cable provider turned off the HDCP (high definition copy protection), it's possible that the cable box is treating the cable as being incapable of carrying the audio. Try using the Analog audio option, described above. You may want to check if your cables are fully-compliant with the HDMI specification (and HDCP). Then get the HDCP enabled in the cable box. Similarly, check the audio output settings for the cable box. (If you can access the Settings for the cable box without a service call, you should look at the Audio and Display settings. My cable box has Display options for HDMI versus DVI cables, as well as a choice for Digital Audio for the HDMI option in the Display sub-menu.)
I hope these ideas help. If you need more information, add a comment with the settings for your Audio and Display settings. The manual is available on the TC-L32X2 support page, http://shop.panasonic.com/support-only/TC-L32X2.html . The direct link to the manual is currently ftp://ftp.panasonic.com/television/om/tc-l32x2_en_om.pdf . See page 28 for the Audio menu options. Since you tried three cables, I think the odds of all three being bad is slim.
Nov 01, 2017 | Panasonic TCL32X2 32 in. HD-Ready LCD TV
Panasonic TCL32X2 32 in. HD-Ready LCD TV Logo
410 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
