What sort of lead should I use to connect my Sanyo CE27LC6-B - 27" Widescreen HD Ready LCD TV to my laptop?
    President:
  • 556 Answers
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Posted on Nov 13, 2010
How do I connect the stand
You may find the installation booklet in the box.
Oct 15, 2014 | Philips BDL3215E - 32" LCD TV - widescreen...
When a overhead light is switched on,the tv sound goes and picture breaks up
sounds like distortion from this overhead light you are turning on.
try TV else where in another room for example.. see if it reacts to other equipment being turned on
Jun 02, 2013 | Panasonic TX-L32C4B 32-inch Widescreen HD...
How can I connect my laptop to my LCD TV through HDMI cable (brand:LG) (model:LF15 series) HD ready?
You'll need to make sure that your laptop & LCD TV have an HDMI port. If they both do, simply connect an HDMI cable from your laptop to your LCD TV and make sure the input on the LCD TV is set to receive A/V from the HDMI port.
Jan 11, 2013 | LG Televison & Video
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
We were just given a pl26 tv, by can not find where to plug the cable connector into the tv, help
this information may help
32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 ...32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 800:1 6ms ... Front Panel Controls: IR sensor ; LED; Top Panel ... Model: PLTV-32; Product Requirements: HDTV receiver
May 05, 2012 | Protron PLTV-26 26 in. HD-Ready LCD...
Some programs donot show on full screen
Not all programs are broadcast in HD yet. The picture should fill the screen if it is broadcast in HD. The TV will shrink the picture of a SD broadcast to give you a correct picture aspect. SD is broadcast in 16:9 and HD in Widescreen
Hope this explains it.
Kaufman605
Dec 11, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo 32" full hd lcd
New speakers have to be used to get mellow sound after the speaker cones soften a little.
Dec 04, 2010 | Televison & Video
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
