Question about Hoover Nextra HNF 3167 Top Load Washer
Is there a filter to clean or change on a Hoover hnf 7167 washing machine?
Trifect7
  • 57 Answers
SOURCE: hoover nextra hnf 3671 -
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord if you feel qualified.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Posted on Mar 02, 2008
SOURCE: Water leak at rear of
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Posted on Jul 30, 2008
abhishek33
  • 1239 Answers
SOURCE: Hi,Ihave a hoover hnf 7167
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Posted on Sep 12, 2008
barkencoa
  • 3463 Answers
SOURCE: my hoover optima washing machine
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
Posted on Dec 18, 2008
  • 188 Answers
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
Reset button on hoover inter@ct washing machine hnf 9147 z
try this link out you should find how to reset it here-
http://www.manualslib.com/manual/644650/Hoover-Hnf-9167.html?page=37
Sep 26, 2015 | Hoover Washing Machines
What is error 4 hoover hnf 9147 z
It means call a service technician from Hoover as soon as possible.
Feb 03, 2015 | Hoover Washing Machines
Hoover hnf7167 won't start 40 cycle
it is about to go out completely it has lasted as long as any one that I have ever had
Mar 22, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Jun 01, 2009 | Hoover Nextra HNF 3157 Front Load Washer
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
May 12, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
Jul 26, 2008 | Hoover Washing Machines
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Hoover Nextra HNF 3167 Top Load Washer Logo
51 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
