Question about eMachines eME720-4691 Notebook
USB port is faulty we cannot work - eMachines eME720-4691 Notebook
  • 43 Answers
I am assuming that there are other USB ports on your notebook that are working and that all of them are occupied. If this is correct, you can purchase a USB hub that will expand a single USB port on your notebook to a larger number of ports. You may need to have a powered hub depending on the devices that you are connecting. USB hubs are not expensive (under $10). Hard drives, CD/DVDs and other power users will probably require a powered hub.
An example of a USB hub can be found at: http://3btech.net/sublfopopous.html
This is not a product recommendation, but an example of what a hub is and how it could help your situation. You can find many other choices by searching for "USB hub".
It is also possible that your USB port has become disabled and needs to be re-enabled through Windows. Look at CONTROL PANEL; SYSTEM; DEVICE MANAGER; UNIVERSAL SERIAL BUS CONTROLLERS. Then examine each one listed to verify that the system thinks they are working correctly. If not, you can take appropriate action from the tabs on that window.
Posted on Nov 13, 2010
Usb port can't work
There are basically 2 reasons why USB ports will not work besides being faulty.
1. The drivers are not installed (inf files)
2. The ports on certain motherboards can be disabled in the CMOS or BIOS setup.
To check if the USB drivers are installed you can open control panel>device manager. Scroll down to "Universal serial bus controllers and make certain these are present and installed correctly.
Also make sure your USB device is functioning properly by plugging in to a USB port on a different computer.
Please let me know if you need any further assistance.
Best wishes,
Graemevm
Jan 09, 2012 | ASUS P4P800-MX Motherboard
Usb ports not working
If all the USB ports are not working, this indicates that the USB controller circuitry on the motherboard has gone faulty. If you can however get one port working, you would be able to use an expansion card with usb ports. To rectify the USB controller problem, you would need to have the laptop checked by a technician to trace where the fault lies.
Jul 28, 2011 | Toshiba Satellite A135-S2276 Notebook
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sir my transcend pendrive is not detecting in pc.wht will be the exact issue.
Possibilities are:-
1. Pendrive faulty/defective
2. PC's USB Ports faulty
To check your Pendrive working, plug it to another PC USB port ie functional.
Hope it helps.
Feb 26, 2011 | Computers & Internet
Hi, the ethernet port located in the back of my computer appears to be faulty. I am unable to connect to a modem/router successfully due to this problem, also my USB ports don't appear to be working. Can...
If your lan card is faukty then you have to replace the LAN card. But as regards the USB ports not functioning the best thing to do is to install the usb drivers for your PC. When you install the USB port drivers for the PC the PC will be able to accept plug and play USB internet modems.
The drivers for your usb port can be located when you go to device manager select USB ports and it will take you to the drivers for the ports.
Hope this solution has been helpful?
Dec 30, 2010 | Computers & Internet
USB PORT IS NOT WORKING IN MY CANON PRINTER MP730
hi
check the cord which you are using it may be faulty.
try the usb port with another cord if it does not work, then it is probably you change the usb port.
thanks
Jun 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My magic jack could not work with my vista home premium desk top computer
In what way would it not work?
You may have a faulty USB port or may be disabled in the system BIOS. Check for USB port functionality first since magic jack uses the USB port.
Get ahold of a flash-drive and see if the flash drive works in the port. You may have a faulty magic jack device if nothing else.
Jan 07, 2010 | Computers & Internet
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Problem with my Dell Inspiron 5160 USB port
This is either a driver glitch or a faulty port. Start by uninstalling the usb drivers from the device manager, then reboot. The machine will find the ports and reinstall the drivers automatically. If this doesn't fix it, then the ports are faulty and will need replaced. The usb ports are very simple devices, when the drivers are present, they either work or they don't. Other than the drivers, they have nothing else to go bad other than the port itself, and in general, when one goes they all go.
Aug 22, 2008 | Dell Inspiron 5160 Notebook
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
eMachines eME720-4691 Notebook Logo
165 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
