Question about Black & Decker Alligator Electric Lopper
How to remove access cover - Black & Decker Alligator Electric Lopper
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
How do i replace the front driver side headlight bulb and the rear passenger taillight bulb
Turn wheels to gain access to the headlamp door access cover in the wheelhouse liner.
Remove the headlamp door access cover fastener.
Remove the headlamp door access cover from the vehicle.
Dec 08, 2014 | 2004 Chevrolet SSR
HOW TO CHANG A FUEL PUMP ON 2002 BMW X5 3DI
BMW has a unique habit, the automaker has, for years, used the rear passenger area of its cars to mount items like batteries, fuel pumps and fuel pump sender units. It makes sense in a weird way as it does keep wire runs short and makes access to the fuel pump and the sender unit more convenient than in other vehicles. The downside is that you have to disassemble the passenger seat to gain access to the fuel pump and the fuel pump sender.
To replace the fuel pump, you have to remove the rear seat starting with the child safety seat holddown covers. The child seat holddown covers simply unclip and slide away.
Next, you have to remove loosen the rear seat back so you can remove the rear seat bottom. The rear seat back slides up slightly so the seat bottom can be removed. You remove the rear seat bottom, being careful to watch the seatbelt lap attachment units, by moving it out and forward. It may take several movements to do this. Once the seat is free, swing it vertical and out of the way.
With the rear seat out of the way, you will see the fuel pump and fuel pump sender access cover panel. It is a sheet of composite material with four access holes per side. Remove any holddown clips or nuts that you find in the access cover panel, being careful to leave it in place, for the moment. Once you have removed the clips or nuts that are used to hold down the access cover panel , place them in a secure spot out of the way, such as an ashtray or one of the cargo trays to ensure you that the clips or nuts don't become victims of the repair (they are easily lost).
Now, it's time to orient yourself to the fuel pump and fuel sender sites. Looking toward the rear of the BMW, you will find the fuel pump on the left (passenger side) of the vehicle and the fuel pump sender unit on the right (driver side).
Next, find the access holes in the fuel pump cover seal plate. Insert a 10 mm ratchet socket and drive arm and remove the fuel pump cover plate access screws.
Since you have already loosened the fuel pump and fuel pump sender access cover panel, simply remove the sheet of composite material and expose the fuel pump cover seal plate. Now, remove the metal fuel pump cover seal plate.
On removing the fuel pump cover seal plate, you have access to the fuel pump assembly. Looking at the top of the fuel pump assembly, you will see the power plug and fuel line.
Next, remove the power plug from the left hand side of the fuel and loosen the fuel line clamp. After loosening the fuel line clamp, remove the fuel line and place it in a small metal container to trap any fuel that might leak out.
Next, remove the fuel pump retaining ring. There is a special tool available from BMW to handle this chore. Or, if you take a flat-bladed screwdriver and a small hammer and place the blade of the screwdriver against one of the raised nubs on the retaining ring, you can gently tap the screwdriver, exerting pressure toward the rear of the X5, to loosen the retaining ring. Once it is loosened, unscrew the ring by hand.
Now, remove the fuel pump assembly and place it on a cloth on the ground. The cloth is there to absorb any leakage.
Now, take the replacement fuel pump and insert it into fuel pump site and replace the retaining ring, spinning it tight by hand. Then, take the screwdriver and hammer again and gently tap the ring, exerting pressure toward the front of the vehicle.
Reattach the power lead and fuel line, tightening the fuel line clamp, and you are finished.
Clean up and complete the repair by replacing the fuel pump cover seal plate and fuel pump access cover panel. Reinsert any clips or nuts to hold down the fuel pump access cover panel. And, reinsert the four 10 mm nuts for the fuel pump cover seal plate through the access cover panel and torque them down.
Finish up by reversing the seat removal steps.
That's it, you have just finished removing and replacing the fuel pump.
Nov 22, 2014 | BMW Cars & Trucks
The heater blower stopped working and the fuse is not blown?
Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
To Remove:
  1. Remove the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  5. Disconnect the electrical connector from the blower motor.
  6. Remove the blower motor mounting bolts.
  7. Remove the blower motor insulating cover.
  8. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting bolts.
  3. Connect the electrical connector to the blower motor.
  4. Connect the cooling tube to the blower motor.
  5. Install the rear coolant recovery reservoir mounting stud.
  6. Install the coolant reservoir.
  7. Install the PCM.
W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
To Remove:
  1. Remove the PCM.
  4. Disconnect the electrical connector from the blower motor.
  5. Move the PCM connectors out of the way.
  6. Remove the blower motor access cover screws. CAUTION
    Do not cut any deeper than necessary in order to remove the access cover.
  7. Cut through the access cover on the cut line using a sharp utility knife.
  8. Disconnect the cooling tube from the blower motor.
  9. Remove the blower motor mounting bolts.
  10. Remove the blower motor.
To Install:
  3. Connect the cooling tube to the blower motor.
  4. Install the blower motor access cover.
  5. Install the blower motor access cover retaining screws.
  6. Using black weather-strip adhesive, seal the cut line.
  7. Connect the blower motor electrical connector.
  8. Reposition the PCM connectors.
  9. Install the rear coolant recovery reservoir mounting stud.
  10. Install the coolant reservoir.
  11. Install the PCM.
Feb 08, 2011 | 1996 Chevrolet Blazer
How do you get access to battery on 2006 kawasaki zx14
You heed to remove the front seat and fuel tank cover. The access cover for the battery is on the right side of the bike just beneath the fuel tank cover. There are 5 - 8mm bolts that must be removed to access the battery. Some people leave the top 8 mm bolt out when re-assembling so your dont have to remove the fuel tank cover next time.
Steve
Jan 02, 2011 | 2006 kawasaki ZX-14
How do i replace a heater core in my 97 blazer
Heater Core Removal & Installation To Remove:
  1. Remove the heater/vent module.
  2. Remove the heater core access cover screws.
  3. Remove the heater core access cover.
  4. Remove the heater core from the heater/vent module
To Install:
  1. Install the heater core to the heater/vent module.
  2. Install the heater core access cover and screws to the heater/vent module.
  3. Install the heater/vent module assembly to the vehicle.
Dec 19, 2010 | 1997 Chevrolet Blazer
How to change blowermotor on 2001 gmc jimmy
To Remove:
  1. Remove the PCM.
To Install:
  7. Install the PCM.
To Remove:
  1. Remove the PCM.
To Install:
Dec 08, 2010 | 2001 GMC Jimmy
How do i install a fuel pump on a 2000 buick century
The fuel tank is in the fuel tank, some models of cars have a fuel pump access cover in the trunk. Remove carpet in trunk to see if there is an access cover. If there is remove cover , disconnect fuel lines and electrical connections and remove sending unit from tank. Pump will be attached to fuel lines on sending unit. If no access cover you must remove tank from vehicle, this is a much harder procedure.Unless you have the proper tools and a hoist it is best left to experts.
Oct 29, 2010 | 2000 Buick Century
Heater core replacement
To Install:
Oct 08, 2010 | 2003 Chevrolet Blazer
Location of the blower motor
from autozone.com: access from engine compartment
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
  1. Disconnect negative battery cable.
Fig. 1: Exploded view of the blower motor assembly
  1. For the 3.1L engine, remove the alternator belt, then remove the alternator and position aside.
  2. For the 2.5L and 3.3L engines, remove the power steering pressure hose from the power steering pump.
  3. For the 3.0L engine, remove the serpentine belt.
  4. For the 3.0L and 3.3L engines, remove the retaining bolts from the power steering pump bracket, then set the pump aside.
  5. Detach the blower electrical connector, then, if accessible, remove the cooling tube.
When cutting the blower motor cover, make the cut just the thickness of the cover, which is1/ 8 inch (2mm) thick. Cutting deeper than that may damage the cooling tube.
For 1992-98 vehicles, partially cut the blower motor case cover, as shown on the cover. Cutting completely around the cover is NOT required. Swing the cut potion of the cover down.
973a989.gif Fig. 2: Some later model vehicles require you to cut the case, on the indicated lines, in order to access the blower motor
  1. If previously accessible, disconnect the cooling tube.
  2. Unfasten the attaching screws/bolts and remove the blower motor from the case.
Fig. 3: On 3.0L engines, you must remove the power steering pump for access to the blower motor
  1. If necessary, remove the fan from the blower motor.
  2. The installation is the reverse of the removal procedure.
  3. If the case was cut during removal, secure the cover using the three retaining clips. Tighten the blower motor screws to 44 inch lbs. (5 Nm).
  4. Connect the negative battery cable, then start the engine and check the blower motor for proper operation.
Sep 22, 2010 | 1997 Pontiac Grand Am
Black & Decker Alligator Electric Lopper Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
