Question about Microsoft Computers & Internet
Operation could not be completed. enter the printer name was incorrectly, or the specified printer has losts it is connection to the server. for more information click help
    Problem Solver:
  • 10 Answers
  1. Are u on an office / home, NETWORK?
  2. Is the printer connected directly to your PC? or
  3. Is the printer connected to a router?
  4. How is the printer connected Wired / Wi-Fi?
  5. Have u been able to print on this printer before?
  6. When was the last successful print taken?
  7. Any new Antivirus Installed?
Sorry bout so many questions, just makes it easier to answer than going in circles later on
Cheers Eddie
Posted on Nov 13, 2010
How to specify a host name for jetdirect 170x
Connect the print server to the router with an ethernet cable and connect the server to the printer. Find the IP address for the printer/server by pushing the "test" button on the print server. The IP address will be listed on the paper printed during the test.
Nov 12, 2013 | HP Jetdirect 170x Print Server
I am getting an oracle error while trying to login. The error says: ORA-12545; Connect failed because target host or object doesnot exist. What could be the probable error?
ORA-12545: Connect failed because target host or object does not exist Cause: The address specified is not valid, or the program being connected to does not exist.
Action: Ensure the ADDRESS parameters have been entered correctly; the most likely incorrect parameter is the node name. Ensure that the executable for the server exists (perhaps "oracle" is missing.) If the protocol is TCP/IP, edit the TNSNAMES.ORA file to change the host name to a numeric IP address and try again.
Aug 16, 2010 | Computers & Internet
How can make printer server
sine you talk about XP pro, you can just share a printer by right clicking it on the pc that you want to make server, and click share. give it a name, and on the other pc's you can connect to this printer by browsing the network or clicking => START => RUN => than enter the name of the print server pc like this: \\PCNAME and hit enter. the pc will show the printer, double click it and it will be added to your pc, you can print from it now.
hope this helps
Dec 31, 2009 | Microsoft Windows XP Professional With...
LDAP issues with Konica C451
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
Aug 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I can't scan.
The Scanning feature must resolve the name you have entered into the host location in the one touch screen. If the system is not able to resolve the name to an address it will fail. The easy way out of this is to enter the destination IP address. The hard way is to fix the reason the printer can not resolve destination name to an Ip address. That will require fixing a DNS problem on your network
Mar 27, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Shared printing problem
Go to Control panel open printers and faxes delete the existing printer, re install it by clicking the add printer, browse the path to your boss machine, when you find the printer auto install it.
Dec 18, 2008 | HP Business Inkjet 1000 Printer
I can't <send\receive> the mai in the window mail In the Tasks page said : Send4message(s) using ttyff failed
Most likely cause is the server settings are incorrect, it is very unlikely that a server is called ttyff.
mail servers are typically named
mail.ISPname.com
smtp.ISPname.com
The quickest way to confirm is to go to the mail service provider's mail setup web page, and ensure that the account settings are as specified. Servers both incoming and outgoing, and account names and passwords must be as specified
Jul 28, 2008 | Computers & Internet
Problem
How to lock machine,
and How to unlock the machine.
my email id is prashanthmbs@yahoomail.com
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Problem
yeppers...looks like a case of the missing printer. Remove it and add again. I'm assuming it's plug and play. You should be able to browse your network for it, right?
Got backup?
Feb 10, 2008 | Office Equipment & Supplies
Sharp Copy Machine
You don't say if you are using a server/client network or a peer-to-peer. Go to START >printers and Faxes >Add a printer >Next and select A Network printer select Connect to the printer and then enter the path to the printer eg \\server\printer name
Oct 01, 2007 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
