Question about Garden
Buying mig welder seen a few on Ebay dont know if any good??Names like MigStar,Magnum,WeldSmart,Krieger,etc cant spend too much
    Brigadier General:
  • 4,088 Answers
It's better to buy locally if you can--that way, you can verify that the machine actually works. Ebay buys are a 'pig-in-a-poke', because many of them are being sold because of defects. Harbor Freight stores have some new inexpensive mig welders (Chinese made) that you might investigate. If nothing locally, check them out on-line. Hope this helps!
Posted on Nov 13, 2010
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Owners manual for a migstar 120
trying to get a copy of an owner manual for a Migstar 120 welder
Apr 22, 2013 | Welding Tools
I need a new gun for my Powermig 110 the triger brok off any Idea where I can find or if Tweco makes one that will fit.
If you can afford it upgrade to the 140 or bigger. Tools are also a great investment. Don't buy cheap. Look at ebay for replacement parts for the 100. When you go to ebay look at the feedback % and how many times they have sold, not bought. I've had good luck there but I am very picky.
Bryan
Feb 07, 2012 | Astro Pneumatic ASTRO ECONOMY SHOP TOOLS
My magnum 100l is flowing gas even when the power is off. How do I get it apart to look inside?
Hi:
Your gun is not the problem, your problem is the solenoid valve on your machine (welder) that solenoid valve must got dirt or debri from the hose and the closing needle it's stuck . Just replace it, it will be cheaper than replacing your gun.
Have a great day.
Jun 21, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
Migstar 250 1 yr old used little, the other day when pulling trigget no solenoid for gas or wire feed in continuoud and spot mode, only gas in stitch mode.
I would recommend checking the connection at the cable to the welder. It has happened to me a few times that the connector was in but not making contact.
Good luck Joe
Feb 16, 2011 | Welding Tools
This is a new 135g I bought on ebay the wire feeder worked one time now it will do nothing the shaft will not move
I would suggest you go to a welding supply,
not mention ebay,and get it fixed correctly
and have them explain how to set it up etc
Feb 05, 2011 | V, Inc. 135g Mig Mag Welder Machine Gas ...
I cant seem to get consistant penetration even though i am a competant welder and have set the unit up to manafacturers spec's as well as a few degree's either way. The material is clean, well earthed, i...
try a different outlet it seems you are loosing electrical power supply and it surges in and out causing this problem.also try cleaning the inside of the wire cable every time you chance the roll of wire i use brake clean spray it inside until it pours out the other end you will be surprised what you see come out.any comments are appreciated
Nov 21, 2010 | Lincoln Mig Welder Trigger Switch Magnum...
Clarke pro 90 gas mig welder wont penetrate
I have the same problem, please that´s some one knows how to fix this?
Apr 19, 2010 | Clarke Power Products WE6480 MIG95 Flux...
Mig welder schematic wanted for magnum auto mig 150 turbo cheers
if you call the maker of the welder you can be sure the one they give you is right and its normaly free and faxed or mailed right to you.
Oct 25, 2009 | Welding Tools
Need the gun for a lincoln 3200 welder
Gonna be expensive About $125-$200. Sometimes its cheaper to get a new unit. They sell for about $300 on Ebay. I believe this will work on your unit Its $85 on ebay.
http://cgi.ebay.com/Lincoln-Magnum-100L-MIG-Gun-Replacement-10-150A_W0QQitemZ330349527430QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cea5dc186&_trksid=p3286.c0.m14
Jul 29, 2009 | Welding Tools
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
