Question about Whirlpool Dryers
My Whirlpool Dryer MOD LER7620LWO is not heating to dry. Tumbler etc all seeem to be working fine. This si a 5-6 year old purchase new. It has always been a slow dryer but never stopped heating o dry
    President:
  • 2,468 Answers
Remove the 9 screws on the rear cover then one by one remove wires to the high limit thermostat on the lower right side next to the heating element,then up above that theres a thermal cutoff thermostat,then on the left side on the blower housing theres a thermal fuse white in color about an inch long by 1/4" wide,and a cycling thermostat,check all of these for continuity with an ohmmeter they should all show near 0 ohms resistance or like a fuse its either good or bad,then if all checks out ok,then it could be the heating element on the right lower side....good luck.make sure to unplug the unit before doing any testing and for your safety.....thank you.daniel
Posted on Nov 13, 2010
Electric Whirlpool dryer m11036334, dryer will not always heat
Sounds like a limit switch has broken. Doesn't sound too expensive to fix.
Nov 14, 2016 | Whirlpool Dryers
Why won't the dryer heat
the heater element and/or the stats may need replacing
cheap on ebay.........
cheers
Jul 28, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
My dryer is not heating. Seeems to be running fine except every few minutes makes a churning type noise and there is no heat. We cleaned the lint trap and the exhaust hose. Is this an expensive repair?...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Frigidaire GLGQ332A Gas Dryer
Dryer is spinning but the burner wont fire up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
