I have forgot the password for my tenda router i.p address 192.168.0.1 how do i get it?
  • 32 Answers
You can only reset the router to its factory default setting by pressing the reset on the back. Instructions for resetting the router & the factory user name / password are located in the manual.
Posted on Nov 13, 2010
2 Suggested Answers
SOURCE: can not acess Http://192 168
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access it then press RESET button for 10 seconds it is in back side of router. Then all settings defaults then you can access it with default above ip. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 08, 2010
What is the login password en tenda router
Defaults for your router are:
Username:Admin
Password: Admin
If you have changed this you may need to hardware reset your router
Jul 18, 2014 | BestPriceCables Tenda 3G622R 300Mbps...
How can i set a new password intenda wireless router?
You will need an lan or wlan connection to your router, the service/ip address, 1st, open to your web browser, 2nd, type in your service/ ip address into the link, 3rd, login to your router's settings, and find the wireless setting. if you do not understand these steps, please consult you manual for "login to router" settings, or find the web site, and find user assistance.
Jul 09, 2014 | TP-LINK Tenda W311R WirelessN Router AP...
Just want to know on how to hide my username and password on my tenda router bcoz upon typing 192.168.0.1 in the address bar, the username and password automatically viewed by everybody and also my wifi...
Just want to know on how to hide my username and password on my tenda router bcoz upon typing 192.168.0.1 in the address bar, the username and password automatically viewed by everybody and also my wifi password was also viewed. pls help..
Sep 25, 2013 | TP-LINK Tenda W311R WirelessN Router AP...
I cant access the 192,168,2,1
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
How to remove password from tenda wireless
Push and hold th reset button for 30 seconds or so, the will reset to factory settings. This may help: http://www.tomshardware.com/forum/32272-43-tenda-w311r-installation
Dec 20, 2012 | TP-LINK Tenda W311R WirelessN Router AP...
Trying to set new password for tenda wireless router
you need to access the router's GUI page to change the security key of the routers/
remember, once you change the security key, it should be changed in all the devices you got connected wireless.
you can access the GUI page by typing either 192.168.0.1 or 192.168.1.1 (most of the routers have this default setting) in address bar of internet explorer.
you can find the exact numbers by going to start>run>type "cmd">type "ipconfig">enter
you will see the default gateway number which is the one you need to type in a address bar of the internet explorer. (these steps work only if you get the computer connected with the Ethernet cable first to the router)
once you access the gui page, you have an option to change the wireless key under wireless section>security.
need to mention that when you access the GUI page, you will be welcomed by a username and password log in option. the default username and password again is admin in most cases. if it doesn't work ,check with the manual of the router you got.
if you still need more clarifications or steps on this, please reply to the post.
Apr 01, 2012 | Port Designs Tenda W307R-103421 Router
Im using a tenda wireless broadband..my problem is i cant get the right pre-shared key pls help
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | TP-LINK Tenda W311R WirelessN Router AP...
I cannot connect "wireless" with my TENDA model
TENDA model W268R default IP 192.168.0.1 username: admin password: admin
Reset the Router and reconfigure again....
Jul 04, 2011 | Computers & Internet
How to instal 3g611R Tenda router
You do have to install any drivers for a "Router", to link your modem & PC to access the internet you just have to configure the router's settings.
Read this link @ How do I configure a Tenda router?
3G611R Default IP:192.168.0.1
3G611R Default Password:admin
3G611R Default Username:admin
Hope it helps.
Apr 08, 2011 | Computers & Internet
Computers & Internet Logo
938 people viewed this question
David Payne
David Payne
