Question about Dell Inspiron 1525 Laptop
Back side panel too heat producing.restarting every 1 hour once .
    Scholar:
  • 103 Answers
I had the same problem, but after removing dust from the inside it works just fine. Although the fan was working it prevented cooling. I recommend trying that first, there's a manual at the dell-page how to open it, and it really needs just a cleaning
Posted on Nov 13, 2010
My kenmore gas dryer will start if it is cool but once you use it for a while and stop it it will not restart
you have a thermastat going out or bad, its heating up and closing, and not releasing when it cools, Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced.
Jul 03, 2011 | Kenmore Dryers
Picture goes out but sound remains. After restarting picture is back. Recently the picture would not come back after restart. Next day it worked again.
The tv have 1 or 2 long LCD inverter boards are dying.These 1 or 2 long LCD inverter boards help the tv to have a backlight to produce a picture on to the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 LCD long inverter boards for the replacement.
Mar 23, 2011 | Dynex DX-LCD32-09 LCD TV
Hey there, I have a Westpoint NOFROST De Luxe Tropical frige, model # WRK 297.1. The freezer section is forming ice and the circulation fan is making alot of noise due to ice being formed behind the back...
I believe your problem is the defroster circuit . There are only three components on most refrigerators unless you have something real special . Kidding . They are as follows : defrost timer , heating element , and defrost cut out switch . The defrost timer cycles the refrigerator out of normal operation and into defrost mode once every six to eight hours depending on the unit . When in this mode everything shuts off , compressor , circulation fan , and condenser fan is so equipped . To eliminate the circulation fan , you'll have to keep an eye on your refrigerator checking in every half hour or so for six hours to eight hours and see if it stops working . If it does , then we know the timer is working correctly and the problem will be the heating element or cutout switch . The heating element is checked with an ohm meter. Usually they burn out when they go bad and you will read infinite resistance. The defrost cutout switch should read 0-1 ohms when the freezer temperature is 40° F or lower. If the heating element checks good , in other words it shows to have resistance usually between 30 and 100 ohms, replace the cutout switch . If the circulation fan never shuts off and the unit continues to run without shutting down after a six or eight hour Time cycle , replace the defrost timer . Good luck
Feb 22, 2011 | Refrigerators
I have a whirlpool sided by side refrigerator purchased in 2001, I have been hearing a sizzling sound in the bottom of freezer, I opened the door last night and saw the hot coils and water dripping on...
The problem here is that the defrost drain hose is clogged.
It is a fairly simple solution if you have a little time and patience. You will need a Phillip's screwdriver, a few bath towels, some hot water and a turkey baster.
- First turn the refrigerator off or unplug the unit.
- Open the freezer and remove all the food and shelves, you will need to use the screwdriver and take the rails off of the side walls, as you take them off line them up on the floor so you remember which ones go in which order
- Take the screws out of the back panel, the panel starts near the bottom of the freezer and comes up about 3 feet ( 1 meter ).
- Once the few screws are removed remove the light bulb is there is one. it may be hot so be careful.
- Now pull out about an inch on the top of this panel you just took the screws out of. Slide the panel upward about 2 or 3 inches. It may be a bit hard and bend but that is alright
- With it lifted you will see a small pan in the bottom of the freezer, it will most likely be filled with ice.
- Use the hot water to melt the ice and towels to clean up the mess.
DO NOT USE ANYTHING SHARP OR "CHISEL". You can damage the coils, use heat and hot water only, if you use a blow dryer or heat be careful not to heat up the side walls as they will melt.
- Once the ice is clear you will see a hole in the bottom pan about the size of a dime. Use the turkey baster and flush hot water in the hole until it flows again.
- While you are doing all this keep towels around the perimeter of the refrigerator to soak up any water that flows out the bottom, leave the towels there for a day or so to make sure you get it all up, a little leak for a few hours after the repair would be normal
- Once the drain tube is clear, you can put it back together and turn it back on
- The red coil and sizzling noise are normal. Every 8 - 10 hours your refrigerator goes into a defrost cycle to remove excess frost. The water from this heat normally goes down your drain into a pan under the frig and evaporates.
Apr 18, 2010 | Whirlpool ET1FHTXM Top Freezer...
Samsung frig stopped cooling-
most new fridges have a self defrost mode once or twice a day because the coils ice up if it collects alot of moisture. it shuts the compressor down and turns on a heat coil to defrost (which can take up to a half an hour). usually on a timer that is adjustable.
Jul 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Oct 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Monitor takes 1/2 hour to warm up
You need to check the fly back of your monitor maybe experience over heat. It is possible need for replacement but not the whole monitor only the fly back.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 02, 2007 | Computers & Internet
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Dell Inspiron 1525 Laptop Logo
29 people viewed this question
Alun Cox
