Question about Pioneer Audio Players & Recorders
Pioneer pdr-609 new laser installed but still wont recognise any type of cd loaded it just spins for a few seconds while trying to detect type of disc then no disc on display even on new pre recorded
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
petraman7
  • 1175 Answers
SOURCE: 3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Posted on Jun 26, 2008
SOURCE: fixing Pioneer PDR-555RW
Receaving display blinks (check disk) sometimes cd will read but after about one minut the cd eather stops or skips. I tryed to clean the cd player with T'nB cleaning cd but did not solve the problem. Can you help me?
Posted on Nov 24, 2008
kevbuzz
SOURCE: hi can i record on my pioneer pdr 609 cd without
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Posted on Jul 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have PIONEER PDR 609 C.D RECORDER AND I HAVE
Not a very specific problem description...
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
Posted on Jan 31, 2010
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Disc does not spin
First do a lens celeanup, just in case.If it does not work It may be the motor. But before opening it I suggest to check if it is under guarantee.
Feb 24, 2008 | Pioneer PD-R555RW CD Recorder
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
How do you finalize after recording a cd?
What model?
My Pioneer PDR-609 requires pressing the Finalize button; then after it displays the time it would take to finalize it I press Pause and it counts down.
Feb 03, 2010 | Audio Players & Recorders
Jan 31, 2010 | Audio Players & Recorders
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
Pioneer PD-F505 Cd Player - The player picks up the CD and it starts spinning. A high pitch squeel sound starts as soon as the CD starts to spin. The unit spins the CD for about two to three seconds and...
Sound like laser assy defected in any case you need a Technician from Pioneer or they are trained by Pioneer is very complicated to remove the laser and replace it you need an osilloscope to aligment a new laser and special disc to do that. It might not worth to repair it, the laser itself a bout $110.00 Aus
Nov 30, 2008 | Pioneer Audio Players & Recorders
110 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
