Question about RIM BlackBerry Curve 8310 Smartphone
My blackberry ball wont scroll down how do i fix this
    Guru:
  • 832 Answers
Hello there!
Don't do something or try to open your Blackberry phone. As you know, the circuitry of such cellphones are sensitive. I suggest that bring your unit to a Blackberry service center near you.
However, you may do this simple troubleshoot, turn off your unit, then remove the battery and install it back. This is one way of resetting or booting the system.
Regards,
fossildude
Posted on Nov 13, 2010
s_4u_11
  • 535 Answers
SOURCE: Trackball on Blackberry Curve not working properly
chak button conteact has been dry or key pad point has been dry then it will happen if u not have proper knoweged of how to open it then go with a profession service man
Posted on Oct 13, 2008
robshow
  • 367 Answers
SOURCE: blackberry rolling ball will not roll down
Cleaning the track ball on blackberry phones. Remove the metal ring then the ball mechanism remember how you removed it because it needs to go in the same way. You can also try removing the battery from phone taking a qtip with alcohol the higher the percentage of alcohol the better. and wiping and rolling the ball around even without removing it from the phone. this usually helps unless the ball is extremely dirty. Below are step by step ins for removing the ball. just follow the link
Removing blackberry tracball (non BOLD)
Posted on Jan 02, 2009
SOURCE: Blackberry Curve Rolly Ball Trouble
First how bad troubleshooting by manufacturer-sellers is! Not a word on this. Second, third and fourth, always use with case, no pockets, no bottom of bags; use with clean hands; and, clean very carefully with cotton swab mildly moistened with nail polish remover (from your favorite woman, mine gave me the idea), and then very carefully clean ball with it and wipe with dry swab. Tatahhhhhhhhhhhhh TManning
Posted on Jan 27, 2009
GrinningFool
  • 625 Answers
SOURCE: The ball won't scroll down
This is usually caused by the blackberry trackball getting dirty or gummed up!
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean. Do this a few times until the q-tip stays clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Posted on Aug 03, 2009
  • 16 Answers
SOURCE: my blackberry's scrolling ball wont roll
Most trackball movement problems can be rectified by cleaning the trackball. Try the following steps to see if it helps tp resolve the issue you are having;
1) Turn the unit off, open the back cover and pull the battery out,
2) Take a paper towel, dampen it with water...nothing else, making sure that the towel is only damp and not soaking wet,
3) Rub the damp paper towel on the trackball, over and over, making sure to rub up, down, side-to-side and every which way. This should clean the trackball and remove whatever is causing it to not move smoothly.
4) Wait a minute or two and replace the battery and cover. Once the unit has rebooted, try moving the trackball again. It should be better.
Cheers!
Posted on Dec 31, 2009
My blackberry scroll bar is malfunctioning - sometimes I cannot get it to scroll up and down only scrolls side to side.
You can try removing the scroll ball and cleaning it, that could be the reason why it wont scroll up and down.
www.usedcellphoneshop.com
Jun 07, 2010 | RIM BlackBerry Pearl 8100
When i push scroll button down nothing works only side to side up and down works
This is very common for the blackberry's. Sometimes the trackball gets full of lent and dirt which won't allow the wheels to move. The chrome ring around the ball just pops off and the track ball should come out. Try cleaning it with a small brush. If this doesn't fix the problem, then a new track ball can be purchased on ebay for less than $5
Dec 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry ball wont click down
Try CPR in New York City. They are faster than the manufacturer, and cheaper! They have a usual turnaround of 1-2 business days. And if you become a fan on their facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Sep 07, 2009 | RIM BlackBerry Pearl 8100
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
The track ball on my black berry pearl doesnt scroll down
yes sure!
just take it apart and clean the track ball area with amedical alcohol and brush, remove dirt from it!
plz give a good rate
that happend with mines once!!
Mar 25, 2009 | RIM BlackBerry Pearl 8100
Roller ball
All you have to do is take a sheet of paper with print on it. Take the battery out of you phone. Next do a figure eight motion with the ball side down on the phone about 10 times. There is something on the ink on the paper that will make this work again. good luck
Feb 12, 2009 | Verizon Communications BlackBerry Pearl...
8100 rollerball wont scroll down
sounds like the ball is gummed up.. there are several sites that will show, with pics, how to remove the ball assembly and tear it apart to clean it... but be careful.. it is not as easy as it looks.. i ended up buying a new ball off of ebay for under $12 shipped.. so i suggest that route
Dec 31, 2008 | RIM BlackBerry Pearl Smartphone
Blackberry rolling ball will not roll down
Dec 28, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
364 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
