Question about Toshiba 36A42 36" TV
Whillyi broke the cable tv input off the back of the tv
    Top Expert:
  • Toshiba Master
  • 74,118 Answers
Hello
If it has broken, there is no way other than replace it with same type. For that you have to open your tv, pull out the board that contains that socket, will be combined one, resolder it out from the board, and go for the same type and leg confuguration. Replaceing it will solve the probelm.OK
Posted on Nov 13, 2010
Cable input broke off, can this be soldered back on or does it need to be replaced?
dont try ro solder this because if theres any joint left lose , corbon may get accumalated there cuasin damage to ur TV.Go for a replacement , it is'nt that costly
Jan 09, 2010 | GE 31GT740 31" TV
Cable tech broke coaxial input off, and knocked tv over against the wall, and now no inputs work and the TV has problems even turning on . What can this be ? Can it be repaired ?
the coaxial connector you need to replace this ie just put a new one in.did he do a check to see if the tv is getting power??. with his meter??. the power supply is the most important check the fuse
Apr 23, 2009 | RCA Televison & Video
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
My tv broke that i had my converter box hooked up to so bought another one now i cant get a signal, my converter box wont stay on.
if it is hooked up through the componant, or composite cables, that is the red white yellow, or the red blue green red white, you have to take note of what input it is plugged into on the back of the tv, they are labled, then hit the input on the remote control to match the input your plugged into, even if your using the screw on cable, stioo have to put it on that input, also try turning your tv to chanel 3
Jan 08, 2009 | Televison & Video
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Cable connector broke off of the television.
You can by an RFmodulator and a set of composite cables to get the cable signal into the tv provided you have audio and video inputs. You will then need to tune tv to the proper input to view.
Hope this helps you.
Sep 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philip TV - Cable connection on back of TV broke off. How do I repair it?
If the rf input is broken off you can usually get the rf input replaced pretty cheap from a tv repair store, if it is the component or composite inputs then you have to replace the Small signal Board which is a way more expensive fix
Aug 11, 2008 | Televison & Video
Co-ax input broke off in back
Good Day, aprilpatino;
If your TV has video, components or HDMI inputs you can by pass the 'rf' connector. You must have a cable, sat box or vcr in order to do so. Hook cable output from 'box' to the TV's input. Change TV's input with remote for the proper 'hooked-up' input.
Good Luck, Big Irish.
Jul 09, 2008 | Televison & Video
Toshiba 36A42 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
