Question about Canon PIXMA® mini260 InkJet Photo Printer
Qdo ligo uma Impressora ELA FAZ, Barulho 1, Trava e aparece nd Tela Erro 6000 uma luz piscando do poder FICA Entre laranja e azul, Trava ... Tudo isso desligando
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: luz copy piscando e mensagem de erro 6A00
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
ML 1610 no power
tenho essta impressora, samsung ML-1610 e quando liga, ela reinicia mas fica com as duas luzes piscando, uma vermelha e outra verde, o que devo faser pra funcionar normal, o toner ? novo.***.
Digerson.
Apr 26, 2011 | Samsung ML 1610 Laser Printer
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
Estou com uma S600 quando mando imprimir 10 etiquetas ela imprime 6 etiquetas e trava acende os leds paper /ribom, pause e cancel. O que eu faço para resolvers este problema?
ajusta o sensor que esta em baixo da printhead, carrega no ultimo botao ate a luz do calibrar acenda e enter. Atravez do driver e possivel ajustar a printer, confirma imprimindo a label de configuracao e ve se esta de acordo com o tipo de etiquetas, na pior das hipoteses, faz o reset to factory defult.
Nov 09, 2010 | Zebra Z4Mplus Label Printer
MODELO KF 390 esta aparecendo uma tela azul escrito error fatal file: dog:UI line: 0
eu coloquei algumas musicas no meu celular e agora ele nem quer ligar.desde ontem eu nao consigo abrir a minha pasta de musicas
eu acho que ele ta com virus mas eu nao tem como scanear ele porque nao tem jeito de ligar
so aparece uma tela azul
Sep 12, 2010 | Cell Phones
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Sharp al 1000
pressione a letra C então abotoam a densidade então C e abotoam Desnsity simultaneamente. A tela sairá. Incorpore 24 e pressione o COMEçO. Incorpore 07 e pressione o COMEçO outra vez. E você é todo ajustou-se.
Presiona letra C densidad C densidad, la pantalla se apaga. Entra a 24 y presiona START. Entra a 07. Presiona Start
Nov 17, 2008 | Sharp AL 1631 Copier
I need help
a minha canera quando liga fica
com a tela azul e esta escrito q
lens erro oq eu fasso
a lente nao entra mas
mas ela caiu no chao.
me ajude
Nov 04, 2007 | HP PhotoSmart M627 Digital Camera
Canon PIXMA® mini260 InkJet Photo Printer Logo
43 people viewed this question
old marine
old marine
