Question about Rangemaster 110 (Gas) Kitchen Range
Hi, my rangemaster 110 has push button ignition, but has suddenly stopped working. the two ovens are fine but the burners & grill will not light unless you use a match. can you help? Malcolm Heaver
SOURCE: Rangemaster 110
i have had the same problem with rangemaster 110, r/h solinoid,i purchased a replacement from an authorized dealer, same fault within 6 months, i had to purchase a replacement so they could check the first replacement was faulty before they refund my money. now the second one has failed. so we have decided to use it until the l/h oven gives up (hopefully sooner than later) then we will be buying another double oven, but it will not be rangemaster.
delboyp
Posted on Oct 28, 2008
  • 10 Answers
SOURCE: Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Posted on Feb 20, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
the ffd comes has a unit with a gas tap connected to it. can be brought for £90.99 from manufactures.
  • 188 Answers
SOURCE: Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Posted on Mar 26, 2009
SOURCE: rangemaster 110
I have an Aga Rangemaster 110 which was stuck on flashing 0.00 / auto too. The solution was to press the 2 left hand buttons simultaneously and then the "+" button to set the clock.
Posted on Mar 29, 2009
Hi, I have a Rangemaster 110 (electric double oven), which has a double grill. Unfortunately one half of the grill has blown - not working. Is it easy to repair? Thanks a lot - Krisztina
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
Dec 28, 2010 | Rangemaster Range Cookers Kitchener 110...
Oven ignites but the ignition continues to click
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 08, 2010 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 LPG Range (5364) right hand oven lights but flame only stays low? What is the likely problem please
Is this new and recently converted to LP-Gas? Did you install it and convert it or did you have a professional do it? It sounds to me like the wrong size orifice for the oven may have been put in. Was the appliance regulator converted? When you flip the cap, it allows more pressure to the burners, but this affects all stovetop & oven burners, not just one burner. Some ovens require converting the oven thermostat too, but not sure if it applies to this brand. Check your owner's manual and make sure all the steps in the conversion were done. If you had a pro install and convert it, call them back to fix it. Douglas
Jun 12, 2010 | Rangemaster 110 (Gas) Kitchen Range
When I turn on the main oven it lights up but continuously ignites, had this problem before after cooking a fish pie and lasagne (possibly sauce spilling into back of oven), Previously cleaned burner and...
Yes. If any moisture or food particles get into the ignition area, especially moisture the igniter will continue to ignite and drive you nuts. Be careful when cooking not to do this by layering the rack with aluminum foil to catch any spillage.
May 28, 2010 | Rangemaster Proffessional 110 Gas Kitchen...
Their was apower cut now the clock and fan oven wont work. but power to the grill and gas is still functioning . rangemaster 110
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Apr 15, 2010 | Rangemaster 110 (Gas) Kitchen Range
Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Apr 01, 2009 | Rangemaster 110 (Gas) Kitchen Range
Feb 26, 2009 | Rangemaster 110 (Gas) Kitchen Range
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Gas oven lights but goes out.
i have a technogas cooker but the oven goes off from time to time do u have solution for this problem thank u
Nov 07, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Gas) Kitchen Range Logo
42 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
