Question about Compaq Presario 5000 PC Desktop
The power LED of my compaq monitor blinks when powered. Sometimes it works well but after 20 minutes display disappears and it blinks the power LED.
  • Compaq Master
  • 1,183 Answers
if the light blinks orange after a few minutes after use. The monitor would either require repair or replacement since the power board has gone bad.
Thanks
Proton
Posted on Nov 13, 2010
I have a LG 700E and after switching on the monitor's power LED blinking continueously and there is no display and no relay sound at startup, Another monitor if attached to the same system is working...
Hi, I believe that the monitor has gone to sleep mode (hybernate mode). Please check and confirm that it is not running in this mode.(System properties) or display modes. Good luck.
Jun 13, 2011 | LG Computers & Internet
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Blinking of moniter 700e lg
I think that two capacitors in the powers supply circuitry(incise the monitor) has gone bad. Just open and you'll see them.
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Jul 27, 2009 | LG Studioworks 700S 17" CRT Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 08, 2009 | LG 500LC Monitor
LG 700E monitor's power LED blinking continueously, no displaySolution.............
Jan 23, 2009 | LG Studioworks 700S 17" CRT Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
I have a compaq 15" monitor which has no display.
1.poewr LED blinking or not.if in case LED blinks one time. problem in LOT .Cheak horzontal Transistor also.
1a) power out put voltages
2.drypoints in neck board.
3.cheak display cable.
Dec 19, 2008 | SAMTRON 55V 15" CRT Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 5000 PC Desktop Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
