Question about HP 510 Notebook
My hp 510 can not boot from the CD room when I start the machine (not allowing formatting). The CD rom works after booting
  • HP Master
  • 2,385 Answers
If the CD ROM is ok, then boot from another CD it shows that only CD is faulty
Posted on Nov 13, 2010
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
How i'll start to formate my dv6 hp laptop 2163tx step by step i'hv my recovery cd
Put the CD/DVD in the machine and re-boot it. If it doesn't readt it from the start you'll need to change the boot drive order in the machine's BIOS Setup which you get to when the machine is just starting up (look for the key to press during the boot up process). After you set the CD ROM to be the first boot drive - the recovery disk should boot the machine and get you going.
Jan 05, 2012 | Computers & Internet
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
How to instal in pc
Hi, you haven't said for what operating system, but for XP. First you will need to change your primary boot device to CD Rom, to do this boot into BIOS by pressing the F1 key during initial boot fase, save changes after boot device has been selected, insert windows CD into drive and reboot. Select boot from CD, which appears during initial boot fase. Allow files to be installed, once finished you will need to delete operating system and repartition hard drive, then format hard drive. Once this completes PC will reboot, ignor boot from CD and allow PC to boot normally and it will start to install XP.
Aug 05, 2010 | Computers & Internet
System running slower that normal, and freezes randomly.
1st you go BIOS setup and change the Boot Order or Boot sequence.
  • Select Boot From CD Rom.
  • Then Save the setting .
  • Insert the Window XP Cd in the Cd Driver .
  • when the computer start again .
  • It will boot from Cd Rom.
Then you follow the instruction and install the windows.
Mar 13, 2010 | Soyo Dragon P4I845PE Barebone
An old machine but it's the one I use. The
I recommend using another computer to get a cd-rom driver so you can download the drivers.
I also suggest changing boot up to cd rom first before hard-drive.
Then put cd in driver, then boot pc and it should recognize and load cd rom to install software.
Jul 09, 2009 | HP Vectra VL400 PC Desktop
Boot problem
open your bios setup and check the cd rom is recognized and check the boot priority is set to allow to boot from the cd rom first.
Feb 20, 2009 | Dell Computers & Internet
Machine won't recognize CD-ROM after harddrive format
When booting up select whichever key gets you into the Bios. Normally either F2 or delete. Once in the Bios, find the boot up sequence and by the instructions that will be there to change the sequence change it to Floppy Drive, then CD Rom, then your hard drive with Windows on it. Press F10 to save and reboot.
Nov 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Nx6110 boot issues
Try using an external CD drive. Some machines will allow you to boot from an external and some won't. If yours does and the external will boot from the CD, then your CD drive is bad. Usually it's the optical eye that goes out on these, unfortunately you have to replace the whole thing.
Jul 02, 2008 | HP Compaq nx6110 PC Laptop
HP 510 Notebook Logo
218 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
