My optical drive is locked. i can't load up any discs or take infomation off with a memory pen
I assume you mean locked by software. Have a look at any security software sunning as some of these can lock a drive. I have found this under Vista on some of the newer machines.
Posted on Jun 19, 2008
    Sergeant:
    Champion:
  • 326 Answers
Suggest that U explain more for better help. Has it worked? Have U tried to uninstall and reinstall with drivers only?
Recording error E454039000
please see your instru. manual and go to the section troubleshooting.
and fix it. God bless you
see this possibles causes.
  1. Disc loaded upside-down.
  2. Transportation lock engaged.
  3. Dirty, scratched, or defective disc.
  4. Dirty or damaged objective lens.
  5. Loading (mechanical) not completed reliably.
  6. Damaged lens suspension or damaged lens cover preventing free movement.
  7. Dirt, gummed up lubrication, or damage in sled drive mechanism.
  8. Dirty/defective limit switch or sensor.
  9. Defective spindle motor.
  10. Spindle table height incorrectly set.
  11. Bad component in optical pickup.
  12. Cracks in ribbon cable to optical pickup.
  13. Need to adjust servo (or less likely, optical) alignment.
  14. Faulty power supply, electronics, or control logic.
  15. Bad connections including missing/erratic optical deck shield.
  16. External interference.
Sep 23, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My pen drive has become write protected and now I want to remove write protection from my pen drive,please help me.
Hi Sir.
Please look carefully at your usb pen-drive to see if there is a small switch on there somewhere that is used to lock and unlock the drive. perhaps you may have accidentally put it in the lock position.
If there is a laser pointer on the drive then using the laser pointer may have caused you to accidentally switch to the write protected mode. most drives have a lock/unlock switch on the pen-drive itself...unless it has a program installed on the drive that has encrypted and locked the drives read/write ability. Please let me know if you have success.
Thank you!
Dec 03, 2010 | Generic Memory USB 2.0 128MB Black Pen...
I have bought HP 8 GB Pendrive from Ebay.in before 8 days But it is not working Now It shows error that pendrive is Read only What is the solution?
What is the model of your HP Pen Drive?
Is there any small slider switch on the pen drive? usually there is one on the SD memory cards to lock and unlock it. If the switch is in locked position then the memory card/pen drive will be read only and if it is in unlocked mode then you can write to it.
In case there is no switch on the pen drive, then try formatting it and check if you can format this drive or not? You may also try accessing/formatting the drive from some other computer.
Feb 02, 2010 | Electronics - Others
Pen drive shows device is write protected while formatting. So please give me solution so that I can format the Pen drive & use it again. Kingston Pen drive with 4 GB capacity. Using Windows XP...
if you see your pen drive properly you will find a lock that you need to switch to other side for unlock device
this lock make device write protected
hope it helped you
Sep 30, 2009 | Electronics - Others
I have problem of copying from computer unto a pen drive
Check for possible issue with virus and spyware. Scan the computer with antivirus and spyware. Try connecting a different pen drive and check.
Aug 18, 2009 | Imation (15175) Magneto-Optical Disk...
I am not able to copy from my computer unto a pen drive
go to my computer, right click on the pend rive and click on properties. if the details below is showing 0byte that means the pen drive is no longer good.
Pen drive cannot open
Please install the usb driver and check again.
Jul 02, 2009 | Electronics - Others
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
8 GB usb pen drive
Sounds like it's fried. Pen drive sometimes go bad, especially is they are pulled out of a machine without stopping it first. Not much you can do, sorry.
Jan 22, 2008 | Electronics - Others
Keeps saying loading but never shows picture
take your set to tech the lens need to be adjust or the strip is getting in the way.
Feb 19, 2007 | Sungale PD708 Portable DVD Player with...
Computers & Internet Logo
David Payne
David Payne
