Question about Samsung HT-P10 Theater System
How to open the Samsung HT-P10 Subwoofer - Samsung HT-P10 Theater System
Samsung ht-p10 subwoofer not volume
Posted on Jan 27, 2011
  • hemant00726 Feb 01, 2011
    samsung ht-p10 subwoofer not volume
My samsung ht-p10 home theater system displays "No Disc"
..I would assume that you have carefully cleaned the lense and inspected the flexible ribbon cable..try replacing the spindle motor..in our case they are not expensive..good luck Elben
Aug 24, 2012 | Samsung HT-P10 Theater System
The lazer leans not working
If this is confirmed then the OPTICAL HEAD must be replaced with the same type. Before this is done you can clean the lens as a last attempt.
Use all precaution when replacing the head, need to remove the static shorting in the new head before replacing. Take help.
Sep 10, 2011 | Samsung HT-P10 Theater System
I have a Samsung HT-C550, is there a separate power switch or something for the Sub-woofer? It seems to not have a lot of power.
If it is making any sound at all then it is "on".
Check your subwoofer function and level with Test Tones (page 29) and Auto Sound Calibration (page 30) and don't expect too much from an 8-lb 6.5" subwoofer and a multichannel amp that only draws 75 watts of electricity. Maybe place the sub nearer to a corner.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/search.html?q=Samsung+HT-C550
Mar 23, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
My samsung ht-p10 theater system displays protection then shut down
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 06, 2011 | Samsung HT-P10 Theater System
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
Jan 23, 2011 | Samsung HT-X50 System
My HT-P10 displays "protection" and
The amplifier has a bad channel or is bad in general, and will need replacing. In some cases, it's a separate board and can be replaced itself, but in others, everything is on one board(except the power supply unit) and warrants just having he unit replaced.
Dec 04, 2010 | Samsung HT-P10 Theater System
I Have samsung HT-P10, Pl let me know the laser lens number is used for the same or let me know any satiable lens which can be used for HT-P10
Hi.. my home theater system HT-P10.... is not working.... Any of its function do not respond after it being kept on...! Any of its function are not working.... the dvd player doest open up.. nor sound comes out of auxiliary, radio or any other function... and the 5.1 display is never shown.. it shows 2 channels only..
and this had been the problem frm last 1year.. at the beginning of the year... it was working suddenly in between and at times it use to turn out inactive but from last 6-7 months it is totally inactive...!
I contacted samsung.co.in and the guys came down to my house telling that we dont hold any spare parts of system we cannot do anythin...a do they say we do not repair...!
So what to do to repair it.. can it be..? nd can i ever use its sond sytem only.. in any form.?
Sep 14, 2010 | Samsung HT-P10 Theater System
SAMSUNG HT-P10 DIGITAL HOME THEATER SYSTEM wont play DVDs
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
System is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
Jul 16, 2009 | Samsung HT-AS720ST Theater System
Samsung HT-P10 Theater System Logo
411 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
