IESHIMS.DLL error opening file - Computers & Internet
This is a Internet Explorer Compatibility Shims, and a part of Windows Internet Explorer developed by Microsoft Corporation. It is basically a system and hidden file, usually located in the "Program Files" subfolder and its usual size is 196,096 bytes. The Ieshims.dll is a 32/64-bit Dynamic Linked Library of code components for a graphics User Interface style application. This process is safe and disabling it is dangerous since programs in your computer need it for working correctly. There is no known risks associated to this file unless it is modified by virus. It can be downloaded from the internet.
Common Causes of ieshims.dll Errors:
a. This file was removed when a program was uninstalled.
b. Overwriting of this file with an older version or with a version that is incompatible with other programs.
c. Incomplete or unsuccessful installation of a program.
d. Corruption of the file due to virus infection or hardware failures.
Caution: Installing / uninstalling software and modifying system components may leave your system registry fragmented with obsolete, corrupted or harmful files.
Posted on Nov 13, 2010
Getting an error on outlook mapi cant find the msncon.dll file
what version operating system did you install on . most likely it is not compatible with your OS
Jun 28, 2015 | Microsoft Office Outlook 2003 for PC
I am trying to update my adobe flash player pro but it says s that I am missing a msvcr110.dll file from windows I guess?
If you want to download and install the msvcr11.dll file, click on the link below.
Once the link is open, click on HOW TO INSTALL and click on Download Zip file. Later extract the file and execute the file to be installed.
Click here to Download the DLL File msvcr110 dll free download
Regards,
Sean
Mar 19, 2014 | Adobe Systems Adobe Flash Player
It just frequently pops up on the screen - t8 Ext P Ex. dll is missing
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error
Your computer will not work properly if a Windows Dynamic-Link Library (.dll) file is damaged or missing. When this happens, you will receive an error message similar to this: "[program name] Illegal system DLL relocation."
The .dll file type contains instructions, or code, to run scripts that open dialog boxes.
These important graphical elements are necessary for computer user interaction in most software programs.
There is a simple way to keep all of your .dll files healthy, so you rarely lose valuable time restoring lost or broken links.
Connect your computer to the Internet.
Click "Start" and then click "Run" if you have the Windows XP operating system. For other systems, simply open Internet Explorer and click "Safety," then click "Windows Update."
Type "wupdmgr" in the "Run" dialog box to run Microsoft Update.
Click "Express" to find out if your computer requires new updates.
Press "Install Updates" if any are available.
Otherwise, close the Microsoft Update window.
Update your anti-virus program and then immediately scan all of the files on your computer.
Open the software program that gave the .dll notice to see if error messages still occur.
If so, continue to the next step.
Reinstall the affected software program to replace the damaged or missing .DLL file.
If the issue is still not resolved, contact Microsoft Support.
Fix DLL Errors With Freeware
A Microsoft Windows DLL has data that is necessary to run various software programs.
If a DLL file is defective, the software using the file will not open or run properly.
DLL error messages can stem from a number of system issues, such as a bad program installation, registry issues and missing DLL files.
You may receive error messages from numerous programs when a DLL is corrupt, because many programs use the same DLL.
Running freeware to fix a DLL error is a viable alternative when you cannot repair the DLL manually.
Visit the Regsofts website.
Click "Download Now" to install Registry Repair 2.0.
http://www.regsofts.com/free_registry_repair/registry_repair.htm
Run the "RegpairSetup.exe" setup file.
Click "Next" at the prompts and agree to the terms of Registry Repair 2.0. Click "Finish" to open the application.
Click "Start Scan" to find DLL errors on your system. Place a check by "Non-existent Shared Dlls" once the scan completes. Click "Fix Errors" to repair the DLL errors.
Run RegSeeker 1.55
Navigate the Regsofts website.
http://www.regsofts.com/freeware/regseeker.htm
Click "Download and use for free" to install RegSeeker 1.55.
Run the "RegSeejer.zip" setup file. Click "Next" at the prompts. Agree to the terms of RegSeeker 1.55, then click "Finish" to open the tool.
Click "Clean the Registry." Allow the scan to detect and repair DLL registry issues. Reboot your system once the scan is complete.
Run ACleaner 3.5
Scroll to the bottom of the page, and click "Download and use for free" to install ACleaner 3.5.
http://www.regsofts.com/freeware/privacy-and-registry-cleaner.htm
Save and run the "ACSetup" setup file. Click "Next" at the prompts, and agree to the terms of ACleaner.
Open the software and select "Registry." Choose the Scan Registry option. Select the "fix errors" option once the scan is complete.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Jul 09, 2013 | Computers & Internet
Nikon transfer download problem
You need to manually register the DLL, by following the instructions at this URL:
http://ss64.com/nt/regsvr32.html
You will be using REGSVR32. You may need to unregister the DLL first, then Register it from scratch.
-a.
May 29, 2010 | Cameras
ICverify 3.1 won't open.
the issue is caused by a Microsoft Jet update. in c:\icwin310\backup directory you will find the files needed by icverify. Make a backup of the following files in c:\windows\system32 msjet35.dll
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
Copy the files listed from the c:\icwin310\backup directory to c:\windows\system32 and your error should be no more.
May 28, 2010 | Ic Verify ICVERIFY 3.1
ID error = 0
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
Mar 04, 2009 | Computers & Internet
Error ''DLL C:\WINDOWS\system32\jemobibe.dll is not a valid Window
you computer is virus and trojan horse affected, use latest antivirus. you can find the .dll file to this website..http://www.dll-files.com/dllindex/index-s.shtml
download the missing file
Jan 25, 2009 | Computers & Internet
Videos
try this works for me
Fixing Internet Explorer Javascript Links
Sometimes in IE when you try to open links that open in new windows, they don't open. At the bottom left of the IE window you will see a yellow triangle which indicates its a Javascript problem.
  1. Start » Run » Type regsvr32 /s URLMON.dll
  2. Then do the same but change the DLL names to the following:
    scrrun.dll
    Msxml.dll
    Mshtml.dll
    Shdocvw.dll
    Browseui.dll
    Msjava.dll
    Actprxy.dll
    Jscript.dll
    Vbscript.dll
    oleaut32.dll
  3. Restart IE and your links should be fine.
  4. Alternatively you can copy this in to a text file and save it as a batch file (.bat file)
    regsvr32 /s scrrun.dll
    regsvr32 /s Msxml.dll
    regsvr32 /s Mshtml.dll
    regsvr32 /s Shdocvw.dll
    regsvr32 /s Browseui.dll
    regsvr32 /s Msjava.dll
    regsvr32 /s Actprxy.dll
    regsvr32 /s Jscript.dll
    regsvr32 /s Vbscript.dll
    regsvr32 /s oleaut32.dll
  5. This will re-register all the DLL files. All of the above are used by IE.
Oct 11, 2008 | YouTube Videos
Computers & Internet Logo
401 people viewed this question
David Payne
David Payne
