Question about ESP Ax260 Electric Guitar
My ESP AX260 fell face down off the stand and the impact though not very acute broke the headstock and its completely off the body. The fretboard is intact but the Tune O Matic bridge fell off. I really want to restore my guitar back. I read about a few people fixing broken headstocks. I want to know if I can restore my guitar back to its original shape? Will the fix hold good? Are there any other alternatives?
  • ESP Master
  • 5,603 Answers
I have reattached three headstocks myself as an amateur... I would take your pieces to a Luthier and see what he says about it. The ones I repaired, an acoustic bass required putting in a steel pin to stabilize the joint and some epoxy for the pin as well as the wood glue... an acoustic 6 string required only careful gluing, as did a 5 string banjo...
In all cases Titebond III glue was used for the wood and perfect mateup of the parts was required. Nitrocellulose laquer restored the finish using very fine emery sanding (4000 grit) wet sanding.
The perfect fitup and clamping is mandatory, and the gluing, if done right, will be stronger than the original wood. A key is to have clean LARGE areas of glue contact.
Please do take the unit to a professional Luthier... you should find them in your phone book...
Posted on Nov 13, 2010
Replacing fret board on banjo
Can you place a straightedge from the nut to the bridge and measure down to where the fretboard will be ?
Then you could see what is out there to buy or make.
Sep 28, 2017 | The Music
What Epiphone model did I purchase?
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Feb 21, 2016 | Epiphone Music
What kinds of woods are used in it an how could I customize the guitar body shape without changing the sound?
Woods used in what..guitar bodies???All types are used...Mahogany, spruce, maple, Ash, basswood, even pine of all things...Or a combination of such woods...Guitars are made of tonewoods...maple has a brighter more biting tone than mahogany which is darker sounding. Same with fretboards and necks. All different types of woods. And changing the shape of the body will effect the sound anyway you change it. Especially by the bridge. It really depends on what you are wanting to do. Tell me whats up and what you are thinking of doing. For ideas check out diyguitarist com for more affordable ideas check out http://www.guitarfetish.com/
Feb 22, 2015 | Music
How to adjust truss rod on fender duff mckagan bass
The truss rod adjustment is on the body end of the neck, not at the headstock.
You need to;
remove the strings
unscrew the neck from the body
Make a small adjustment
Re-attach the neck
Re-string the bass
rinse and repeat until satisfied
http://support.fender.com/service_diagrams/p_bass/014-6500-323A_SISD.pdf
Apr 22, 2014 | Fender Musical Instruments Corporation...
How do I slip a shiv between neck and body to raise action
Might want to rethink that....to raise the action is to have the strings higher off the fretboard....if you shim the neck in relation to the body, you'll actually lower the action. To raise the action you need to raise the height of your bridge/saddles. If you want to lower the action and the bridge/saddles are as low as they can go you could remove the neck and insert some card - might have to do some trial and error but to my mind...to shim enough to significantly lower the action, would take a thick shim and you might not get a good tight fit between neck and body. You might actually need a truss rod adjustment - not an amateur adjustment.
Mar 25, 2012 | Music
My ESP LTD EX-50 Guitar haven't a good balance. It's neck is heavier toward the body. I have proplem to play it in standing position cause it's neck going down and I forced to keep it up with...
This is a common problem with odd shaped guitars...lack of balance. You can add a small weight to the opposite side of the guitar strap to counterbalance.
Nov 09, 2011 | ESP Ltd EX-50 Electric Guitar
Strings too far from fretboard
What you are describing is normally referred to as 'high action'. There are a couple of reasons this can occur (I'm assuming that the bass is not broken in any way). Either the neck is bowed forward too much, or the bridge saddles are set too high. If you have recently changed strings to a thicker gauge then the neck bow will need to be adjusted to compensate for the increased tension. If you are not experienced it can be risky attempting to adjust the truss rod by yourself so only proceed if you are happy with the risk!
On the headstock, just behind the nut is the truss rod cover. Remove the screws and cover. Underneath will be a nut, or bolt depending on the instrument. Allen key bolts are most common, but some use a regular nut. Make sure you have exactly the right size tool before you start! With the strings at pitch, make a 1/4 turn clockwise (tightening). Retune the strings and check the action. If it has moved but not enough then try another 1/4 turn. If it has not made any difference then you may need to seek the help of a pro, as the truss rod could be broken.
Again: don't try unless you can afford to risk breaking something! If in doubt take it to your local pro guitar shop and they should be able to help.
Sep 21, 2011 | Rogue LX405 Pro 5 String Bass, Liquid...
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
Fret buzz on new fender david gilmour Nos strat
fret buzz can usually be cured by adjusting the tension rod, unless the neck is permanently warped from excessive heat/humidity (from, say, being left in a car on a summer day).
hold the headstock up to your face, and look down the neck. you should see that the neck is uneven around the frets that buzz. if the neck appears straight when viewed from the headstock, down toward the body, then the strings are just too low, and the bridge should be raised. if you see unevenness in the neck, however, when viewed this way, you should attempt to use the tension rod to straighten the neck.
the tension rod can be adjusted with the hex bolt that pokes out at the base of the headstock, right from under the top of the fretboard. use an allen key to gently turn the tension rod either way until the neck begins to straighten out. if the tension rod cannot straighten the neck, then the neck is warped from heat/humidity.
Mar 09, 2011 | Fender David Gilmour NOS
Need to replace output jack and plate
If this is a classic guitar you should take the fretboard problem to a luthier as you could de-value the unit by working on it yourself.
The jack you can replace yourself. Just connect the wires to the new one the way they came off the old one. There are ONLY two wires. You can get replacement jack from severaal sources.
Aug 24, 2009 | Epiphone Les Paul Studio Electric Guitar
ESP Ax260 Electric Guitar Logo
165 people viewed this question
Top ESP Music Experts
Arora Singh
Arora Singh
Michial Gueffroy
Are you an ESP Music Expert? Answer questions, earn points and help others
